Author Subject: Burning oil
martinh
After a bit of advice if possible please, My gti-6 is burning approximately half a litre of oil every couple of weeks and we're suspecting that it's worn rings as have recently had a top end rebuild where all the valve stem oil seals were replaced along with 12 valves etc.
Is there anything else that would be worth checking before biting the bullet and doing the piston rings?!
Martin
Posted 28th Aug 2009 at 02:48
martinh
Any suggestions people?!
Posted 1st Sep 2009 at 02:17
mechanical_repairs
Think you have hit the nail on the head so to speak, could it be possible the stem seals were not fitted correctly and they have popped off?
Other than that you are going to have to strip it to find out.
Carl
Posted 1st Sep 2009 at 14:08
martinh
Cheers for the reply Carl, I guess it's possible that the stem seals were fitted incorrectly although the chap who did the head rebuild has got a very good reputation.
If it were to be therings are they a complete pain/expensive to do?!
Martin
Posted 2nd Sep 2009 at 01:04
gti6marc
Do a compression test on it cold, then hot and record the readings
Then do it hot with a small amount of oil down the cylinder, pour it down the spark plug hole, if your compression raises it's definately worn rings or bores
DON'T PUT LOTS OF LIQUID INTO THE BORE AS YOU MAY GET A HYDRAULIC LOCK
Posted 2nd Sep 2009 at 01:49
