Author Subject: Sump Sealant?
dommo
I've got some blue silicone Loctite sealant which says is suitable for sumps:
clicky
And I've found a website selling the stuff that says:
# Fix Cure Time @ Temp.: 30 min @ 25
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 25th Aug 2009 at 05:36
if you can, leave it the full 24h.
pot luck if its going to be good after only an hour Sad
how did you manage to knacker the sump??
Posted 25th Aug 2009 at 13:39
dommo
Damn. Do you know of any faster setting sealant?
There's a hump back bridge near me that I've found is more likely to make you jump one way than the other. I went over it one way at 25-30, and it was fine. Went back the other way a few minutes later at 25-30, and it wasn't fine! Balls.
Posted 25th Aug 2009 at 13:41
petert
ThreeBond 1211.
Posted 25th Aug 2009 at 15:08
Genuine Pug stuff seems to hold well, I have used an engine after mounting the sump only 1.5 hours before, and it has been fine. Yes
Stan.
Posted 25th Aug 2009 at 16:54
dommo
The time is no longer an issue, someone else on my course has handed in my assignment for me, phew! I'm just about to use the blue loctite sealant I mentioned in the first post.
Is the oil pump chain usually quite slack? Not slack enough so it could come off but it's got a fair amount of movement in it. Slacker than your typical single speed bike chain?
Posted 25th Aug 2009 at 17:57
rallyerallye
Is Motaquip silicone sealant ok for a sump??
My oil pump chain is fairly slack but not as you say slack enough to come off!! I think that may be normal.
Posted 25th Aug 2009 at 18:11
dommo
Ok the sump has been on for an hour now, but I'll leave it until tomorrow before I stick some oil in, then fingers crossed.
One last thing, I cant seem to figure out how the AC pump goes back on the mounts... And I've no idea how I'm getting the top two nuts for it back on either
I'll have a look on servicebox but if anyone can remember off the top of their head I'd love to know Razz
Posted 25th Aug 2009 at 19:50
mine is also
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Aug 2009 at 05:43
