Author Subject: Running cold
306weasel
What might cause low water temp?
My car always ran at a steady 80deg on the gauge when in motion, but recently it only reads between 70-75deg even when the engine is hot (oil temp reaches 80deg)
And still suffering from unsteady idle and occasional misfire under acceleration.
And the rev counter isn't working... is there a connection?
Thanks
Car#1 306 HDi Meridian 5door, 133Bhp, 225lb.ft Ecosse R/R 20/3/05
Car#2 306 1.4 3door track car with Gti6 power. 167Bhp, 134lb.ft Ecosse R/R 21/10/07
Car#3 Grand Scenic 1.9DCi (Expanding!) family mover.
Posted 25th Aug 2009 at 02:56
cress87
Thermostat stuck open would explain the low temperature. Yes
Posted 25th Aug 2009 at 03:03
306weasel
That was my initial thought, but surely it would still get up to temperature eventually?
Posted 25th Aug 2009 at 03:30
lwgti-6
I wish mine ran that cold perminently! Quit whining about it! lol..
Seriously, check the thermostat. If its open there will be a constant flow of coolant hence the cooler temps.
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 25th Aug 2009 at 04:11
Stuck open thermostats, just had the same thing on mine, changed it, fine now. Yes
Stan.
Posted 25th Aug 2009 at 16:52
306weasel
Cheers!
Was just concerned in case there was any way that although the water temp gauge was reading low, that the actual engine temp could have been much hotter.
Posted 27th Aug 2009 at 01:44
jcphat
Do change it though as running too cool will cost in fuel consumption by running too rich for too long on start-up and there is also a risk of bores wearing excessively through being petrol washed during prolonged cold running.If you remember cars with a manual choke or old VWs with defective auto choke carbs they could kill engines.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 27th Aug 2009 at 12:55
mark-vts
No, not really, can stay really cold.
Xsara VTS > 265BHP WRX > Company car
Remember; only TWATS use text speak
Posted 27th Aug 2009 at 04:47
lotek
mine runs at the lowest point, and when sat in traffic goes upto halfway point , always runs really cold? will changing thermostat make it run warmer? and improve fuel economy?
subscribed
Posted 27th Aug 2009 at 06:36
justinaccurate
A working thermostat will only let the water out of the engine at 82 degrees and above. The temperature is measured on the other side of the thermostat to the engine, so if it is not getting to the 80 mark then chances are its stuck open
As a side note lower temps are nothing to do with the radiator - while aluminium ones do provide better cooling, the thermostat will still let water back into the radiator at 82 degrees.
Im not entirely sure the implications of running cold but I would guess that the car is designed to run at a certain temp and running cold cant be good for the components in the long run
Posted 27th Aug 2009 at 12:35
jcphat
engines require a richened mix to start cold and this is achieved by what for running under load is an unnecessary degree of overfuelling which should reduce when the engine is within it's normal operating range. The stat is there to restrict water flow to the rad until it gets in range. n0 Stat or one stuck open will delay warming up use more fuel and potentially wash oil from the bores. The extreme effect is illustrated by the woman who took her new (Then in the 60's0 Mini back to the supplier to complain about the poor economy and was found to drive with her handbag conveniently swinging from the choke control. Being ancient has some benefits!!
Team Zimmer™
Posted 27th Aug 2009 at 13:03
lotek
lol quality! right i shall be replacing that soon then, where are the best quality ones available from opposed to pug?
Posted 27th Aug 2009 at 15:48
lotek
better yet i shall be replacing today as there only 6 quid from ECP lol
Posted 27th Aug 2009 at 15:51
