displaying posts 1 to 1 of 1
Author Subject: leccy window problem
metalsteve
Hi Guys,
The passenger side leccy window has stopped working on my 3 dr xsi. When i try to operate the window using the controls on the drivers door nothing happens. When i pull the switch on the passenger door back i/e to drive the window up i can hear the regulator motor energise and there is 12 volts present(window is stuck in up position) however when i push the switch forward i would expect the 12v polarity to reverse and the window go down, however nothing happens and no -12v is present. Not tried driving the regulator with +/- 12v yet but i assume its ok.
So i'm guessing broken wire in door loom? Anything else that could cause it?
Ph2 306 XSI
Posted 24th Aug 2009 at 21:31
