Author Subject: camshaft endfloat?
daviewonder
Hi all, Ive fitted a new camshaft to my 2.0 8v engine and when i reassembled everything i noticed that the cam pulley was sitting further out from the head than normal so I gave it a little tap with a rubber hammer and it moved to where it should be. Is this normal for the cam not to have something stopping it from moving from side to side? I suppose it could be called 'end float', should it have some sort of thrust washers or something?
What could cause this to happen?
please help Confused
Why is it that shoe repairers are so good at cutting keys? - Harry Hill.
Posted 24th Aug 2009 at 03:47
sandy
The 2.0 8v has shoulder location on No.1 bearing cap (flywheel end), some older cam castings used fork location at No.5 cap (timing belt end), asper the early 1.6/1.9 heads. take the cam cover back off and have a look.
Posted 27th Aug 2009 at 10:32
daviewonder
yes mate this is exactly right, ive now ordered a fork. cheers
Posted 28th Aug 2009 at 03:00
