Author Subject: rattle from nearside rear suspension
clarke1985car
hi guys i have a really annoying rattle from the nearside rear, its happens over every little bump in the road, i have had it up on the ramp at work and there is nothing obvious, is there any common problems with the torsion bar setup?? any info would be great, thanks lee
clarky
Posted 23rd Aug 2009 at 16:26
pooouk
There is a heat shield covering the N/S rear brake hose that is very close to the back box, is that touching? mine was, just levered it out the way for clearance.
Nick
AKA nick on 205gtidrivers.com
Posted 23rd Aug 2009 at 17:08
cwspellowe
Is the handling shot at all?
Could be the same thing as i've just had to replace, rear subframe mounts. You can't see them easily to check of they're ok, but all my knocking noises have been cured now they've been replaced
Bye bye Sundance Kid Sad
Posted 23rd Aug 2009 at 17:45
mxcrazy
Make sure the bolts that hold the anti roll bar end plates to the arms are done up tight, one of mine was just loose enough to get a tap from the plate hitting the bolt over every little bump, ¼ of a turn and noise was gone, just a suggestion.
Posted 24th Aug 2009 at 03:56
clarke1985car
thanks guys i will try out wot u have said and let u no how i get on thanks lee
clarky
Posted 25th Aug 2009 at 00:22
