Post #41
Mate, you CANNOT unlock your ECU in that way. The immobilier box with the yellow plug is useless for your ECU, you might as well throw it away. You need the corresponding ECU, key chip AND immobiliser to unlock, they are all coded.
So to review, you can't unlock that ECU with any equipment from the old immobiliser set up.
You need to either buy an unlocked ECU or entust the help of a helpful local with a Phase 2 6. You can then plug in the immobiliser (black box), hold your key chip near the receiver and plug in your ECU. Then have the ignition turned on and remove the ECU, it will then be unlocked
Alternatively you can wire in the immobiliser box straight to the ECU along with the key reciever. Then unplug the immobiliser when it has an igniton switched live and you'll get the same result. Wouldn't attempt that unless your handy with wiring though as it's quite involved
(Don't throw your old box away, just a figure of speech, you may need it for your alarm
1990 Cherry Red 205 Gti-6
2000 Mitsubishi Galant V6
