| Author | Subject: Bleeding coolant S16. |
m0gsi
Newbie Location: exeter Registered: 01 Aug 2009 Posts: 19 Status: Offline |
Does anyone have a guide? I've done this a few times but i've heard there is a better method using a bottle. |
are you opening the 3 bleed points?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
surely you just need to bleed it from the top right side (on the rad) bleed point?________________________________________ Team allesclar ® |
not on an S16, there's a bleed point on the top of the thermostat housing like on the gti6, as well as one on the metal pipe along the back of the head, and the heater matrix one.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
I'm pretty sure there are 4 bleed points on the S16 engine, one on the thermostat cover, one at the top of the cylinder head by the vacuum pump, and one on the water pipe that goes across the back of the cylinder head. You may or may not have one on the radiator.If you look in this faq it shows and tells you how to properly fill up the cooling system using a header tank. ________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
