ashcole
| Author | Subject: gti head!! |
ashcole
Newbie Location: chatteris Registered: 21 May 2009 Posts: 44 Status: Offline |
hi i have got a 306 2lt 16v xsi engin sittin in the shed would a gti head fit on to it and would it make any diffrance on the performance side ________________________________________ ashcole |
stan_306gti6
Yes, the head would fit no bother. It would also provide a significant performance increase when used with the GTi-6 inlet and exhaust manifolds and camshafts....![]() Hope this helps, Stan. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
But you wouldn't get the extra piston cooling.________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
ashcole
piston cooling??what that then ________________________________________ ashcole |
ashcole wrote: piston cooling?? what that then I think the GTi-6 block has extra oil jets to keep the underside of the pistons cooler for the extra performance. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
ashcole
ok then dose this matter then ________________________________________ ashcole |
ashcole wrote: ok then dose this matter then If you are going to give it beans all the time. Otherwise, it will probably be alright. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
depends on the year of the XSi block, some did have the piston spray jets.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ashcole
the xsi block 1997________________________________________ ashcole |
just get a proper gti6 lump ????saves fannying around |
ashcole
i keep killin gti6 engins i got 3 now wonted to try somethin diff to see if it would last longer ________________________________________ ashcole |
