Author Subject: Tappy
iangti306
Hi guys pretty new to the site i have a problem with my gti6 its been running fine until last few months, after its got a bit warm it starts to tap its a weird one because it dont always to do it but mainly once its got bit warm it starts to tap, oil was done about 4k ago . any ideas ?
Posted 21st Aug 2009 at 02:05
mark-house
When was the cam belt last changed?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 21st Aug 2009 at 03:13
iangti306
Was done about 10k ago i might check spark plugs tomorow its just weird how it does it after its been warmed up for 5 minutes but dont always seem to be there
Posted 21st Aug 2009 at 03:16
mark-house
Yeah i would check the spark plugs as they have been known to come loose.
Peugeot 306 GTi 6
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 21st Aug 2009 at 03:19
i'd probably change the oil myself if its been 4k and didnt do it before.
what are you using?
Posted 21st Aug 2009 at 03:31
24seven
My money's on a loose spark plug. Failing that could be a worn lifter, in which case best keep on top of those oil changes.
Posted 21st Aug 2009 at 04:28
gti-si
I'm getting this atm, I'm gonna whip the coilpacks off in the morning
1990 Cherry Red 205 Gti-6
2000 Mitsubishi Galant V6
Posted 21st Aug 2009 at 04:59
leesquegti_306-6
my 6 started 2 tap lyk mad had me puzzled, i changed the oil and filter, still no joy, so i went 2 change the plugs and found a couple were loose! so i changed all the plugs since then it is not making any tapping noises, hope this helps
leesque
Posted 22nd Aug 2009 at 06:41
