Author Subject: Fitting a wiper bottle!
honestly3k
Can anyone provide an idiots guide to fitting a replacement windscreen washer bottle into the engine bay on a phase 3 meridian????
Ive just paid for the part and want some clue how to fit it before it arrives.
Is it an easy job?
As it seems housed under some of the metal side skirts in engine bay. Will i need to jack the car up?
Thanks
Posted 21st Aug 2009 at 00:07
allesclar
a quick thing, you will need to remove the drivers side wheel and the inner wheel arch plastic covers
then you can simply unplug the old connecters from the pump to the water jets.
remove the power cable to the pump. there should be 3 screws around holding the bottle in place.
remove these then unscrew the top-up pipe that connects to the water bottle and it should be free to move.
place the new one in and do as above but in reverse order Smile
bobs your uncle!
Team allesclar ®
Posted 21st Aug 2009 at 00:11
honestly3k
Cheers for that!
Im not the slightest mechanically minded but i can handle taking a wheel off and il give that a good go! How hard can it be?!
Thanks allesclar. =)
Posted 21st Aug 2009 at 00:19
allesclar
well i think thats it, like 99.9 percent sure. I remember having to remove it when i changed the radiator and condenser.
Ask if you have a troubles Smile
Team allesclar ®
Posted 21st Aug 2009 at 00:20
