Author Subject: STOP Sign
dave-ov-sheff
hey, i have a 2000 model 306 with a gti kit on it, i got a new exhaust fitted about 3 weeks ago and on the way out of the garage a red stop sign came on, and went off, later that day i got home and turned the car off and back on again, the temp was right up in the 100's but the 2 fans at the front didnt come on, i read that they were supposed to come on at 97degrees, also a closer inspeaction revealed that my radiator had a hole in it, so my radiator and my fans got replaced. the problem still presists though im not sure why.
on the front of my engine they is a plug and when i remove this the stop light goes off, i dont want to drive the car incase i damage it anymore, so basically i need a straight answer on why its doing it, also it isnt my head gasket, i can get more info i you would need me to, the pug dealer tells me nothing apart from its some switchs, although they have been repalce too
one more thing when i bought the car about 6 months ago it came with a diesel fan, just incase it means anything...
thanks you hope you can help
-Dave
dave-ov-sheff has attached the following image:
306 for life Wink
Posted 20th Aug 2009 at 17:53
Is the plug a blue one which plugs into a blue sensor on the power steering pipe?
Posted 20th Aug 2009 at 17:58
dave-ov-sheff
Sorry im a newbie, haham, where would i find this?
(& thanks for the fast reply)(Y)
306 for life Wink
Posted 20th Aug 2009 at 18:01
Which plug is this?
Posted 20th Aug 2009 at 18:10
dave-ov-sheff
Right ok, will have a look now
306 for life Wink
Posted 20th Aug 2009 at 18:13
oecken
dont mean to hijack the thread, but i occasionaly get the oil light and stop light come on when emergency braking, Hard! just for a flash of a second.... guess this doesnt actually mean anything, beside im braking a little too hard...?
Posted 20th Aug 2009 at 18:41
Probably a bit of oil starvation. Mine did it during spirited cornering when the oil was on MIN.
Posted 20th Aug 2009 at 18:44
dave-ov-sheff
Lol, the plug that makes the stop light goes off is brown, this is the only plug i havent replaced as i cant get one nowhere, but why would this make the car overheat?
i took it for a drive just now and i had to stop it was in the 90 again
306 for life Wink
oecken
Cheers il have a check, although i did check before i drove the 600 miles round trip last week and its was just below max Crazy
Posted 20th Aug 2009 at 18:46
Is it the brown plug on the thermostat housing?
It controls the radiator fans.
Posted 20th Aug 2009 at 18:52
dave-ov-sheff
Yeah, the fans dont come on at all
306 for life Wink
Posted 20th Aug 2009 at 18:53
maz-306-xs
i have the same problem on my range xs, need to sort it before i can sell it.
drives fine but gets hot quick and fans dont kick it, plus stop lights always on, will be interested to hear opinions
banned for drifting. back in the s**tbox scene.
Posted 20th Aug 2009 at 18:59
It's always worth checking for air locks in the system.
Posted 20th Aug 2009 at 19:01
dave-ov-sheff
could it be the brown plug? and they is no airlock in the syspem, been bled 3 times :s
306 for life Wink
Posted 20th Aug 2009 at 19:02
dave-ov-sheff
what have you tryed, try tkaing the brown plug out and see if it goes off, brown is on the thermostat housing
306 for life Wink
Posted 20th Aug 2009 at 19:03
Unplugging the brown plug should result in the fans coming on slow and soon after, full. If this is not the case, the 'Bitron' unit under the passenger inner wing could be faulty.
Posted 20th Aug 2009 at 19:12
maz-306-xs
cheers rudolf, as of yet i havent tried anything but this brown plug could be an answer. ill give it ago tomoro and report back.
Posted 20th Aug 2009 at 19:18
dave-ov-sheff
the fans do now come on, not noticed them before, and it isnt overheating, but... the stop light still comes on, i have just tryed a dark plug that goes into the thermostat housing and the stop light has gone off, could i continue using this?
306 for life Wink
Posted 20th Aug 2009 at 19:28
dave-ov-sheff
I have put the blue plug in and the tepm now stays at 87-89, and no stop light, would it be ok to drive now?
306 for life Wink
Posted 20th Aug 2009 at 19:40
If the temp stays low and the fans regulate it then it looks like it should be fine.
Posted 20th Aug 2009 at 19:48
dave-ov-sheff
thanks
306 for life Wink
Posted 20th Aug 2009 at 20:11
nickless_1
Also check your fuses, I had a fuse go which stopped one of the fans (high speed) kicking in. Make sure nothing's blown and if temps are staying low then there shouldn't be a problem.
One thing to note about Peugeot = Shite electrics!! Thumbs up
Proud owner of a Moonstone 6
stue306 wrote:
well you best beat that manc scum now else im going to morrisons to buy the biggest trout i can find,then im coming to your house to slap you round the face with it
To do list: Refurbished alloys, powder coated inlet manifold & rocker covers from Carl. Fix rear heated screen, fix rear wiper (the list it slimming)
Posted 20th Aug 2009 at 22:32
