Author Subject: Clutch arm, how attached?
pooouk
As title, how is the clutch arm on top of the bell housing held on? Mine is loose making the clutch inconsistent and I can see it moving about when the clutch is pressed. I can see what looks like a pinch bolt but the head is covered by the arm.
Cheers,
Nick
AKA nick on 205gtidrivers.com
Posted 20th Aug 2009 at 17:23
there's a 7mm pin in it, no pinch bolt.
sounds like your release shaft nylon bushes are shot,
Posted 20th Aug 2009 at 18:04
pooouk
Cheers mate, had a new clutch 2k ago (before I bought it)
The play is between the arm and the shaft, when you move the arm the shaft doesn't move (literally ½mm at the shaft end) but it feels like loads of play at the pedal end. I'll try knocking the pin in a bit further and see if that helps.
Nick
Posted 20th Aug 2009 at 20:43
