Author Subject: Oil pump removal!!!
rallyerallye
Hi, Can anyone tell me how to get the oil pump off the chain? I have removed the Three 11mm bolts but cant get it off. Thanks
Posted 20th Aug 2009 at 14:21
chris with a pug
you need to tilt it and wiggle and it comes out.angle the top towards the block
Posted 21st Aug 2009 at 23:47
You need to slide out the 'L' shape washer that is underneath it, they do slide out, and once out will give you enough leverage to get the pump off the chain....
Just make sure you remember to put it back again on removal, this 'L' washer/plate is VERY IMPORTANT to to survival of the engine....Yes
Stan.
Posted 22nd Aug 2009 at 15:44
chris with a pug
Stan.
Apparently not all gti6's have them in
Posted 23rd Aug 2009 at 15:21
Stan.
How is this possible? I have checked on Servicebox, and found that there is only one oil pump chain listed for all phases's of the XU10J4RS engine. If you remove this 'L' shape washer then you will incur more slack in the chain. Yes
Also, the oil pump retaining bolts will tend to "bottom out" in there holes and the oil pump will simply circulate oil through it and back to sump during operation, rendering engine damage fairly quickly. Yes
Stan.
Posted 26th Aug 2009 at 17:11
rallyerallye
Worked a treat!!! Cheers Stan.Big grin
Posted 1st Sep 2009 at 01:09
