thanks lee
clarky
| Author | Subject: any tips wen i change my clutch |
clarke1985car
Newbie Location: christchurch Registered: 17 Aug 2009 Posts: 22 Status: Offline |
i need to change my clutch on my gti6 ive never done one on it before does anyone no if i need to drop the sub frame or can i get away with leaving it in, any tips would be good thanks lee ________________________________________ clarky |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
i left my subframe in .. Erm best tip ,make you got another pair of hands to help |
clarke1985car
ok cool im doing it at work can you get the box right out with the frame still in thanks lee________________________________________ clarky |
webster
Seasoned Pro Location: Colchester Registered: 20 May 2007 Posts: 2,059 Status: Offline |
lightened flywheel from rich_w ________________________________________ cress87 wrote: I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past. |
gti-si
Regular Location: Bolton Registered: 29 May 2008 Posts: 228 Status: Offline |
Clutch arm pin ![]() ________________________________________ 1990 Cherry Red 205 Gti-62000 Mitsubishi Galant V6 |
bobdylan_55
Seasoned Pro Location: derby Registered: 28 Mar 2009 Posts: 1,466 Status: Offline |
id say another set of hands and a good jack, they weigh a fair bit________________________________________ 309 GTi6-T |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Get some new fork bearings whilst you have the box off, new clutch cable aswell, will be light as a feather then ![]() ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
danblaze6
Banned!Location: Oxford Registered: 24 May 2009 Posts: 264 Status: Offline |
webzta wrote: lightened flywheel from rich_w + 1. Get a lightened crank pulley while your at it too ________________________________________ XBOX LIVE GAMERTAG: VTECH MONKEY821 |
clarke1985car
do i get my flywheel lightend or is it a new flywheel, and where do i get all the bushes i need for the clutch fork etc________________________________________ clarky |
you'll get them from pegueot or Citroen.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
clarke1985car wrote: do i get my flywheel lightend or is it a new flywheel, and where do i get all the bushes i need for the clutch fork etc It's a new machined flywheel off rich_w and new bushes off Peugeot. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
clarke1985car
thanks to all for the info, changed me clutch its mint now, cheers lee________________________________________ clarky |
