Author Subject: Dodgy Brakes?
greendots
I know the brakes aren't great on the '6, but when I brake in mine there is nothing until the pedal is almost at the floor. It'll start to hiss from around the pedal area then grip slightly.
It was in for a bunch of repairs last week before I bought it, also a full service + MOT and they did not mention any problems with the brakes (other than replacing the rear pads)
Dont fancy driving around in a deathtrap Sad
Posted 15th Aug 2009 at 20:07
allesclar
checked the brake fluid level? i find the brakes on the 6 are awesome.
Team allesclar ®
Posted 15th Aug 2009 at 20:11
greendots
Ah good call mate. I'll get it checked now !
Edit: Levels are fine.
Posted 15th Aug 2009 at 20:54
allesclar
has it been bled properly, ie there is no air in the brake lines?
Team allesclar ®
Posted 15th Aug 2009 at 21:03
greendots
Not sure about that. I'll contact the garage on monday and ask. Is that a hard job to do myself if its required?
Posted 15th Aug 2009 at 21:09
allesclar
nope. they should sort it though, if the problem wasnt there in the first place.
Team allesclar ®
Posted 15th Aug 2009 at 21:12
greendots
I'll have to contact the previous owner to confirm that. He dropped it off at the garage for repairs, service and MOT and I picked it up.
Posted 15th Aug 2009 at 21:26
Sounds like a vacuum leak.
Posted 15th Aug 2009 at 23:48
lotek
gti6 brakes are very good. i would have them looked at.
Posted 16th Aug 2009 at 00:03
kit
Also sounds like it could be the servo that's got a split seal? Does it hiss when your foots not on the pedal?
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 16th Aug 2009 at 01:11
greendots
It only hisses when the pedal is pressed between 25% and 75%. No braking at all before its ½ way down.
Posted 16th Aug 2009 at 03:15
greendots
Had a quick look this morning following up on posts I found about vacuum faults. If I take off the plug from the vacuum pump there is a tiny bit of suction so seems to be working.
The hissing noise is coming from around the pedal area but could not determine exactly where due to having a big head in a small space.
Posted 16th Aug 2009 at 17:39
kit
The hissing sounds like the servo unit mate.
Posted 17th Aug 2009 at 02:29
greendots
After some testing today, it seems you can pump the brakes once or twice and they will pressurise correctly to allow for normal braking.
Posted 19th Aug 2009 at 03:26
Get the system fully checked over by the garage. Yes
It sounds to me like either a vacumm fault or the system has air in it, either way not good to be driving around like it. No
Stan.
Posted 24th Aug 2009 at 16:43
