Author Subject: Tappy Engine
jimmah
I have a tappy engine in my GTI6. Is it easy enough to replace the tappets myself, or just get it in a garage and have someone sort it out for me? Has anyone else gone through this process, and could you give me an idea of time / cost etc?
Is it worth a top end rebuild?
1998 (S) Phase 2 Diablo Red GTI-6
Posted 10th Aug 2009 at 01:10
lotek
get it looked at , most likely not the tappets but a snapped cambelt , that damaged the valves and was repaired wrong. Yes
Posted 10th Aug 2009 at 01:12
jimmah
Ibought the car in May,Its had a new cam belt done, and
Posted 10th Aug 2009 at 01:17
Rich E Forum Admin
Have a search for 'tapping' Yes
As said above a tapping noise is common where the cambelt has failed and the repair work has not been done correctly. Most likely you still have bent valves in the head or possibly worn valve guides.
Excessively worn lifters are rare on these engines.
Posted 10th Aug 2009 at 01:55
jimmah
Well having read a bit further into this i would really like to get it looked at. Is there anywhere local to Southampton area that could do this? and what are the likely costs?
Posted 10th Aug 2009 at 02:25
miles
As said it will be a badly repaired head, I;ve had a few which have been repaired badly and when check found even some valves are still bent, Cost wise it really does depend on what needs replacing, Ball park figure to start from is circa
www.pugracing.com
Posted 10th Aug 2009 at 03:41
rallyerallye
Owselbury Crankshafts in Winchester. Did a good job on mine!!!
Posted 11th Aug 2009 at 16:21
rallyerallye
You will have to take the head to them though.
Posted 11th Aug 2009 at 16:23
jimmah
eek! take it out myself? I'm afraid that I don't trust myself!
Posted 11th Aug 2009 at 23:07
jambo85
I have the same problem. Tapping noise and clutch getting sticky. Im taking mine to garage on friday. Will let you know what they say to mine n the cost
Back to my phase 2 in black on the road.
Phase 3 sold after spending fortune on it.. It wont be missed.
AFTER a phase 3 tailgate in black and front bumper in ace condition.
Posted 12th Aug 2009 at 17:27
lotek
if your in southampton then maybie you should try Lynx Engineering , there not excessively far from you.
Posted 12th Aug 2009 at 17:34
mark-house
And it should be a priority cos a tapping engine is a ticking time bomb if it fails it can take the whole engine with it. You could just remove the head and buy one from Carl Mechanical_Repairs he does them on an exchange basis saves time and effort and probably cheaper than having yours repaired. Thats the way i would go.
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 12th Aug 2009 at 17:37
pompeygti
pug performence in peterfield
6 number 7 is here Wink
Posted 29th Aug 2009 at 03:42
