displaying posts 1 to 25 of 33
Author Subject: knock and a clink
craigy_87
well just noticed a couple of noises coming from the car.
there is a knocking noise started but i can only seem to get it to happen while turning right an reversing an even then its not always, any ideas?
another noise is a higher pitched clink type noise when ever the drivers side wheel hits a bump of some sort again any help would be appreciated.
Posted 9th Aug 2009 at 04:33
craigy_87
think i need to replace the ball joint on the nearside (sure the noise is coming from the offside tho)
whats the difference between these two ball joints from ECP
Clicky
and
Clicky 2
apart from the price obviously lol
Posted 9th Aug 2009 at 20:57
cheaper one says its for PAS, more expensive one is for manual.
Posted 9th Aug 2009 at 21:02
cress87
ECP probably won't know, that's for sure. They've always given me the wrong effing ball joints.
It says one is for PAS cars and one for manual steering yet they list them both for the GTi-6 which is obviously bo***cks as they all have PAS.
The PAS ones should be correct.
Posted 9th Aug 2009 at 21:03
craigy_87
ahhh how did i not notice that, on another note sure i read somewhere about them sending out riveted ones an them being poor, do they only do this kind or do they send out bolted ones
Posted 9th Aug 2009 at 21:08
cress87
They'll only be riveted if you buy complete wishbones. The balljoints should come with 3 bolts/nuts so you can bolt them to existing wishbones. Yes
Posted 9th Aug 2009 at 21:09
craigy_87
good stuff thanks
should hopefully solve the knock
now on to the more high pitched noise that is most defo on the drivers side
Posted 9th Aug 2009 at 21:13
craigy_87
wait before i buy these 16mm ones is there anyway to be sure which size i need??
Posted 9th Aug 2009 at 21:31
cress87
The only way to be totally certain is to measure the current ones. Assuming your car is on it's original hubs, Servicebox should tell you which size you need if you enter the VIN number. Thumbs up
Posted 9th Aug 2009 at 21:36
craigy_87
arm ball joint diam 18
guessing thats 18mm then so different ball joint yet again on ECP lol they dont say 18mm on there but i'm guessing its just the different ones lower down the page from before
Clicky
Posted 9th Aug 2009 at 22:08
cress87
Right, looks like you need 18mm then. That one on ECP there doesn't state a diameter, you need to clarify with them what you actually want I think. Yes
Posted 9th Aug 2009 at 22:17
seeing this in the data on ECp would suggest to me that they are 16mm....
Rp/vin >RP7970
also, thy are the same part number as the second link you posted up there Laugh my ass off
gawd their website sucks!
make sure whatever you buy matches to
3640 48 ARM BALL-JOINT DIAM 18 - XU INJECTION AND IMPROVED SUSPENSION
Posted 9th Aug 2009 at 22:33
craigy_87
aw for f*ck lol i'll have a look down their list then
Posted 9th Aug 2009 at 22:32
craigy_87
ugh cant find it on there
Posted 9th Aug 2009 at 22:44
lotek
the knock could well be the front ARB bushes. change them whist your there Yes
Posted 9th Aug 2009 at 22:50
craigy_87
could be but i didnt get the advisory sheet with my last mot an checking up on it one of the advisorys were nearside ball joint has some play in it.
i've emailed ECP see what they say
Posted 9th Aug 2009 at 23:11
craigy_87
hmmm found this
gazzerdaman wrote:
From what I gather everything with a build code before 07905 is the 16mm ball joints and everything afterwards are 18mm ball joints.
07905 ~ 1 July 1998
is the 07905 the end of the VIN??
if so mine is before that an would suggest 16mm
i'm gonna have to measure them aint I lol
how would i go about that?
Posted 10th Aug 2009 at 00:19
07905 is the first part of the build number on the drive's side suspension turret.
Posted 10th Aug 2009 at 00:42
cress87
You will have to drop the balljoint pin out of the bottom of the hub a little then either put a vernier caliper on it if you have one or another good tip is to try and slot a 17mm spanner onto it. Obviously if the spanner does fit then it's a 16mm ball joint and if it doesn't it's an 18mm. Wink
Posted 10th Aug 2009 at 00:59
craigy_87
well that sounds fun .....
Posted 10th Aug 2009 at 01:12
cress87
Not really. LOL
Posted 10th Aug 2009 at 02:09
rich-6
Dont trust servicebox No Mine were 16mm even though listed as 18mm on servicebox and my car was an R plate
My car wasnt a PBS Laugh
Cool
RIP Pete Sims
Posted 10th Aug 2009 at 02:46
craigy_87
so really its measure it or buy both sizes an send one back
i'll "attempt" to measure it lol
Posted 10th Aug 2009 at 02:52
craigy_87
would the balljoint being fubbered give a lack of feeling or response when turning?
just for a little while now the handling when turning left has been abit "loose" for lack of a better word
Posted 10th Aug 2009 at 05:02
cress87
Could do yes. Yes
Could also be the rear wisbone bushes amongst other things.
Posted 10th Aug 2009 at 05:25
