Author Subject: hybrid anti roll bar fitting
cliff7110
hi guys
have recieved my ARB from ash. got old one out no problem fitted passenger side splined lever and inserted it into the beam and done the m8 screw up loosely.
heres when my problem is. when i put the arb plate on the other side the splines dont line up with the m8 hole in the trailing arm.
also as theres no thread on the arb is it simply smacked on with a hammer.
any replys would be greatly welcomed.
Posted 23rd Jul 2009 at 00:30
SteviePut
Keeps turning it. They'll line up eventually - so I've heard.
Which reminds me, I really must get mine fittedLOL
Posted 23rd Jul 2009 at 00:47
cliff7110
thanks for that. worked a treat and lined up exactly.
Posted 23rd Jul 2009 at 01:59
jamie192
when fitting his arb do u need any other parts? i have one sat here in my bedroom still not fitted. is it simply take old one out put new one in? cheers
Posted 1st Sep 2009 at 04:56
pedro_de_la_cruz
yup straight swap
*R.I.P Pete Sims*
Posted 1st Sep 2009 at 05:00
eddy_gti6
what difference do these actualy make?
Posted 1st Sep 2009 at 05:03
monkeyman
If you want you could get a new gasket/washer set when you fot the new one, but apart form that its a simple swap.
The difference is a much flatter turning ability at speed, and huge grins
Forum Search Clicky
Posted 1st Sep 2009 at 17:04
cliff7110
have had mine fitted for about 2 months now and what a difference, alot flatter when cornering and so much more predicable when the end steps out.
Posted 1st Sep 2009 at 22:10
eddy_gti6
Hmm could maybe do with one of these...
Posted 2nd Sep 2009 at 06:28
jimmy_boy
Errrr... Less roll on the rear! Laugh
Obviously the thicker the arb the more level both trailing arms are going to stay when loaded up one side.
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 2nd Sep 2009 at 18:29
stilly
when doing these guys... make sure you change the foam ring and the rubber rib part... if you dont you may/will get water getting in there and screwing up your trailing arm pins and bearings...Blink
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 8th Sep 2009 at 00:27
shakey
Anyone fancy doing a FAQ on fitting one of these ?
Posted 19th Sep 2009 at 01:51
