Author Subject: Lambda / Oxygen sensor testing FAQ
here's 2 screenshots from Autodata, pretty straightforward task just made a little fiddly by the location of the plug (on top of the gearbox near the thermostat housing)
usually the cause of over-fuelling and rough running, doing these few checks are likely to be a rather more accurate way to diagnose a fault rather than just unplugging it.
as well as the checks below its worth checking the loom back from pins 3 and 4 to the ecu Pins 4 and 22.
ECU Pin 4 is the ECU earth Circuit, and at idle Pin 22 should have a 0-1V fluctuating input signal.
Posted 16th Jul 2009 at 17:22
anybody tried this?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 12th Jul 2013 at 08:50
paulvancraen
Just tried this for you, mine reads 4.4 ohm. And my sensor is working like it should.
Posted 15th Jul 2013 at 15:57
