Author Subject: Brake judder
gota6again
Just changed the front discs and pads, took the car out and braking from 80ish, slowly, the car juddered like mad??
Is this because the discs and pads are new or have I f***ed something up?
Any suggestions welcome, thanks.
Posted 8th Jul 2009 at 01:47
paul_gti6_uk
Sounds like you havent cleaned up the mating surface between the disk and the hub properly. You need to ensure you clean it thoroughly of all built up corrosion etc so its a totally flat surface.
That would be the first thing I'd check anyhow.
China Blue 306GTI-6 Big grin Ph3
Team Now Bikeless Sad
Posted 8th Jul 2009 at 01:54
gota6again
That's probably it, started rushing around in between the rain, I'll check that out, thanks.
Posted 8th Jul 2009 at 02:01
kezman7
Thread resurrection to save opening a new, Did this solve it? I fitted a new drovers hub afew days ago and now i get horrendous judder thought the steering wheel when braking
Posted 9th Mar 2010 at 05:08
