Author Subject: 205 2.0 16 v
superjay
hi all , i have fitted my engine in ,my 205 today and i have a few problems ? the master cylinder sits right on top of the cam covers ? and has now cracked it ,i am useing the 406 mount with the large rubber on ? i think i need a 306 gti6 mount ? as the engine sits to the n/s now ? any ideas or should i just get the 6 mount and see what happens ? Unsure Unsure
CLUB PUG
Posted 3rd Jun 2009 at 04:54
damien
you can use some spacers on the MC to rase it abit or you could grind a little off the cam cover, afew people just use a different mount.
there has been a number of topics about this before try a search for more details
Posted 3rd Jun 2009 at 14:00
anderoo
On my old Mi16 205 I user washers on one side of the MC to angle it away from the camcover.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 3rd Jun 2009 at 14:39
taylorspug
Sounds like you need to use the 6 top mount along with the standard 205 rubber screwed into the body, are you saying the engine is on the p*ss?
Even with a 6 mount you will still need to do something with the master cylinder, as it will be trying to munch into the cambelt cover.
205 GTI6- Ledas, Tran-X diff, billet 4 pots, big bar rear beam, Jenveys and Emerald.
Black P2 306 Gti6- Lowered, PTS rear spoiler- the daily hack!
Posted 3rd Jun 2009 at 16:44
you need to use an XU7/10 top arm from a 405/306/partner/berlingo.
Posted 3rd Jun 2009 at 17:06
superjay
yeah it sits on the p*ss a bit and over to the n/s so the cam cover is directly under the Master cyliner not the one side like carls is siting ? ,im going to get the 6 mount asap and then fingers crossed it will be then ? cos dont fink carl had to do anyfink to the master cyliner did he ?
CLUB PUG
Posted 4th Jun 2009 at 03:20
gti6girl
just cut a bit of the cam cover out the way and fit a 6 mount and all will be fine
Posted 4th Jun 2009 at 03:27
superjay
right got it in nice now as it should ,just used the 6 top mount and the 205 gti gear box just woundering what clutch to use and is the gti fly wheel ok ? i reckon (i will use a 1.9 clutch and the gti6 flywheel in the 1.9 gear box ?) Unsure
CLUB PUG
Posted 5th Jun 2009 at 00:41
daviewonder
do you mean the 1.9 gti clutch or the 1.9 mi16 clutch?
Why is it that shoe repairers are so good at cutting keys? - Harry Hill.
Posted 6th Jun 2009 at 19:19
daviewonder
i would probably use 1.9 mi clutch and flywheel.
Posted 6th Jun 2009 at 19:22
306andy
I'm using a BX 16v Clutch for my 205 GTi-6 Conversion. Its the same as the Mi16v Clutch but is definatly the 1900 version, as the 2000 version of the Mi is the same as the 306, not the 205
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 8th Jun 2009 at 00:00
