displaying posts 1 to 25 of 36
Author Subject: brembo's 607 v6
hoekske
i can get a new set of brembo's (front and rear) for a evo 6 for not to much.
but would these fit the gti6? i know it's not plug and play but that's no difference with 406 brembo's.
should i try to put them on or would it be a no?
Life moves pretty fast. If you don't stop and look around once in a while, you might miss it.
team306tuning
Posted 5th Jun 2009 at 23:32
jamesf
Defo try it. Big brakes are ace. Nothings impossible eh!
Posted 3rd Jun 2009 at 02:12
tvrfan007
I can see the handbrake being interesting as cars with twin piston rears usually sneak a little drum handbrake just inboard of the disc.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 3rd Jun 2009 at 09:30
rallyestyle
You could most likely make the fronts fit yep, but its not really worth playing around with the rears, as said the handbrake would be a pain and there would be no real benefit the way the bias is on the 306.
Just Drive It
Posted 3rd Jun 2009 at 14:20
barry.rs
IIRC the evo brembos are also used on my Alfa and they have been used a couple of times on 6's and rallyes now.
Edit.
The alfas came with 305mm discs that were changed to 330mm in 2004; i have only known people to use the 305mm calipers on a 6/rallye
Posted 3rd Jun 2009 at 15:22
check the mounting points etc, sounds like they are radial if they're similar to Alfa ones.
in which case I have seen some under a 15" wheel around IIRC 302mm pug/citroen discs.
Posted 3rd Jun 2009 at 15:19
hoekske
well need to search for some other brembo's
the ..... sold the to someone else after saying i could have them cald him to pic them up and he tells me they have been picked up by someone else this morning Angry
now i need to search furtherSad
but wich brembo's should i best look fore?
team306tuning
Posted 4th Jun 2009 at 00:25
vts_tibi
a bit off topic, but... how can I find out whether a certain caliper would fit under a wheel or not?
I'm interested in the C5 steelies and Wilwoods combo...
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Jun 2009 at 01:33
hoekske
will the brembo's of a 607 v6 fitt?
i recon they are the same as the 406 ones or not?
team306tuning
Posted 5th Jun 2009 at 03:09
hoekske
found a other tread and they won't fit easely.
think i just have to look for some 406 ones then.
they fit under a cyclone whit xantia disc's wassen't it?
team306tuning
Posted 7th Jun 2009 at 18:27
lukejenks101
They dont fit under cyclones without having big spacers
PS3 I.D - jenkers101
Live i.d - Lukejenks1201
Posted 7th Jun 2009 at 18:36
ablister
607 brembos are huge! 406 ones look tiny compared to these. Different finish to them too, not shiny + smooth like 406 ones
306 rallye, Richard Longman engine
rc10gt
Posted 7th Jun 2009 at 19:05
Rich E Forum Admin
Citroen Sport do adapters for the 607/807 Brembos as they were used on the C2 R2 Challenge cars with 302mm x 26mm discs.
The whole setup is a direct fit to the 306 with 16"+ wheels.
Posted 7th Jun 2009 at 20:28
stu
Wasn't there a French member on here who was using that setup?
I'm sure I've seen it in a thread somewhere, will have a look.
Posted 7th Jun 2009 at 20:37
Rich E Forum Admin
Yes I believe there is a photo on the big thread about brake setups.
Posted 7th Jun 2009 at 20:41
stu
Found it, post # 44 here.
Looks like a tidy setup, wonder if you could use bigger discs with them like Ash's 330mm conversion?
These 406 Brembo conversion's are getting a bit to common for my liking, so I may have to try something different. Laugh
Posted 7th Jun 2009 at 20:56
ablister
607 brembos
offer him 400 euros Wink feck paying
rc10gt
Posted 7th Jun 2009 at 21:45
hoekske
http://link.marktplaats.nl/254094270
this is the link to the 607 brembo's
they don't look much different to the 406 ones to meeUnsure
and where can i find the citroen sportshop site?
have searched in google but nothing turned up Dunno
would it be possible to order those brakets at the citroen dealer?
greets
team306tuning
Posted 7th Jun 2009 at 21:59
cress87
Says on the other thread that those calipers are magnesium and are therefore lighter than the 406 ones. Yes
Posted 7th Jun 2009 at 22:11
cress87
This thread looks worth a read.
You could also PM Yanni to ask where he got the prices for the kit from (Citroen sport site presumably?). Smile
Posted 7th Jun 2009 at 22:14
hmm, 607 seem to be lug mounted like 406, but 807 look radial but no picture of the bracket.
Posted 7th Jun 2009 at 22:19
Rich E Forum Admin
Ah ok, maybe the 607 ones are different then. The 807 ones are radial and mount directly to the hub so there won't be a bracket listed.
Posted 7th Jun 2009 at 22:21
that's what I thought, but the hub pictured is not radial? (didn't cross-ref the part numbers, SB went down shortly after Doh )
Posted 8th Jun 2009 at 03:33
Rich E Forum Admin
Ahhh, so it was you who crashed servicebox! Laugh
Posted 8th Jun 2009 at 04:12
c_j_m
IIRC the discs used with those are 307/308 discs.
I know the XSI 07 used 302mm brakes.
Posted 8th Jun 2009 at 06:51
