displaying posts 1 to 25 of 33
Author Subject: heater matrix bypass
richgti6
Can anybody offer me some advice please? my heater matrix is going and I cant really afford to get it changed so thought I would bypass it.
Is there anybody that has done this? if so, does anybody know the size of the pipe and where is best to join it and how? any pictures would be appreciated just so Im clear with what Im doing.
I'm a novice when it comes to cars.
Thanks for any help
Posted 7th May 2009 at 21:34
jonnie205
pull both heather matrix pipes off engine.
connect outlets on engine together using a piece of pipe or blank the outlets with hose blanks.
refil rad with coolant.
bleed system
Posted 7th May 2009 at 23:16
puglover Banned!
this is what ive done
was going to FAQ it but couldnt be assed
one end is 19mm one is 22mm
get a 180 degree 22mm bend from demon motorsport off ebay, then get a 22mm - 22mm hose joiner and another piece of straight reducer 22mm-19mm and cut it to length and join. Smile
Cost about
Posted 7th May 2009 at 23:26
Rich E Forum Admin
That's tidy Yes
Posted 7th May 2009 at 23:34
One end is 22mm is it? I've got a 19mm U-bend bit of pipe from Siliconhoses.com on mine, slightly chopped at one end. Thought it was a bit tight...LOL
Posted 7th May 2009 at 23:47
monkeyman
If both ends were 22mm you could plumb in your own in car radiator.
Mmmm toasty
Forum Search Clicky
Posted 8th May 2009 at 00:06
birk
You not having any heaters then puglover/adam-b ?
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 8th May 2009 at 00:13
puglover Banned!
nope to much weight LOL
nah i figured my matrix was kerput as i was nearly dieing from coolant fumes when driving so figured instead of spending money on a matrix id bypass it rip the heater out, save some weight and buy heated screen.
will also allow me to run a cage bar across inside the dash as this is part of the Custom cages cage ill be fitting eventually and besides feeling cold is all in the mind. Unsure
I may come to regret this yet but ill save the heater in case i need it back. Apparantly it gets hot inside the car with no carpet anyway from the exhaust etc.
Posted 8th May 2009 at 00:27
birk
LOL crazy lad
Ive been thinking about taking mine out and having no dash, but i reckon when it comes to winter i'd regret it, i dont have a heated screen like you will.
07889376885
Dan
Posted 8th May 2009 at 16:42
hmm, why spend
Posted 8th May 2009 at 16:55
black 6
hmm, why spend
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 8th May 2009 at 19:07
puglover Banned!
hmm, why spend
Posted 8th May 2009 at 23:47
richgti6
Thanks guys. Might just buy a 10 pound heater for the cigarette lighter off ebay until I can afford to get it fixed properly!
Posted 11th May 2009 at 21:12
farmer
Cheers for the pic John, have now copied that setup on my car Smile
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 21st May 2009 at 21:11
dr-evil
hmm, why spend
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 21st May 2009 at 21:47
720puggti
i think my heater matric is blocked too! but i don't think i'll bypass it although is that a nice set up you have puglover Smile i don't think i'd be able to survive without the heater. especially in the winter!
Deepak Gohil
Posted 22nd May 2009 at 00:52
mattgti6phase2
Cost about
Is this the OD of the piping??
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 22nd Sep 2012 at 11:39
jbradders
ID of the hoses
Posted 22nd Sep 2012 at 11:47
mattgti6phase2
Would one piece of 22mm ID hose do the job to as I'm guessing you'd be able to clamp the hose tight enough on the end which is 19mm?
5 x a 306 owner!
Posted 22nd Sep 2012 at 13:04
You possibly could clamp it tight enough Matt, but to be honest for peace of mind I would get the correct size. Yes
Not worth the risk IMO of having a coolant leak and HG pop. Wink
Posted 22nd Sep 2012 at 13:15
mattgti6phase2
Very true. This is only a temp fix as my matrix has started to leak and completely fog up the inside of my car Sad so just gonna bypass for 2 weeks until my mate can help me rip the dash out.
So to clarify 1x22mm ID pipe 1x19mm ID pipe and 1x19mm ID - 22mm ID straight connector?
Also whilst this thread is still on topic, I'm completely removing the AC matrix and box for non AC as i have the AC delete set up. My question is will the fan switch still work with the existing fan speed switch or will i need the non AC switch which has speeds labelled 1-4??
5 x a 306 owner!
Posted 22nd Sep 2012 at 13:32
Yes This is correct.
What is an "AC delete setup" ? Dunno
Posted 22nd Sep 2012 at 15:29
a 306 rallye Thumbs up
Posted 22nd Sep 2012 at 15:47
mattgti6phase2
Also are all non AC matrix's the same across the 306 range? Or will I be presented with a million and one options from my local motor factors?
5 x a 306 owner!
Posted 22nd Sep 2012 at 16:41
You do know youll need the heater box, all the controls, poss some wiring which is stuck to the dash, a heater blower motor, and to cut a new hole in the bulkhead, and block the old one.
Should just be the valeo type.
Posted 22nd Sep 2012 at 18:32
