displaying posts 1 to 25 of 31
Author Subject: 306 Track Car Build
focuson18s
306 Track Car build (Project Rat Racer)
Hi there I am new hear so be gentle lol LOL
Story so far
Well this is the first track car I have ever had let alone attempted to build from scratch so its a bit of a learning curve for me so be patient,
The car started life as a Peugeot 306 Style D at some point in time it has had a full GTI6 conversion, Brakes, Suspension, Engine 3rd Gen Front and Rear End and Interior, the car has been fully converted and the DVLA are aware as the previous MOT'S Show it as a 2L Petrol.
A good friend of mines bought it from ecosse they had it as a trade in with a running problem for
Posted 28th Apr 2009 at 13:55
focuson18s
Update
Well Done some work on the 306 Striped replaced the Piston Rings striped the head its been skimmed Before so new Head needed or new engine I am not sure what way to go yet some update pics are shown below.
Time To Get My Thinking Cap on.
[list]Striped Head[/list]
[list]Replaced Rings[/list]
[list]Removed Dash Board[/list]
[list]Removed Under Seal[/list]
[list]Removed Sound Thick Rubber Mat Behind Dash[/list]
[list]Re-Fitted Pistons to Bottom End[/list]
[list]Looked For New Head/Engine[/list]
Stewart Big grin
Posted 28th Apr 2009 at 13:56
thats an XSI bottom end! Doh
Posted 28th Apr 2009 at 14:54
willygti
Good effort!
Just to clarify, that looks like a GTi bottom end to me Dunno
Here's mine anyway for comparison:
And piston/rod
Team Ducati 748
2003 Subaru Impreza STi
Posted 28th Apr 2009 at 17:33
pistons willy, RS aren't dished like R bottom ends!
Posted 28th Apr 2009 at 15:20
smegal
Does look different to '6 pistons.
Ex SC-6
Now in a Megane R26
Posted 28th Apr 2009 at 16:12
rallyeash
looks like xsi pistons....
309 3dr K20 Type R
Posted 28th Apr 2009 at 17:04
Rich E Forum Admin
That's because they are! Still, fit a set of RS pistons and you're away.
Out of interest, why can't the head be skimmed again? I've got one that's been heavily skimmed and it's still fine.
Posted 28th Apr 2009 at 17:22
depends how much they've been skimmed, you haven't got much material to remove before you get too close to the valve seats sue to the fairly small combustion chamber, about 0.25mm is the safe limit I think.
Posted 28th Apr 2009 at 17:29
willygti
Yeh the second picture i posted was meant to show the pistons and con rod Doh
Now changed
Team Ducati 748
Posted 28th Apr 2009 at 17:32
Rich E Forum Admin
Yeah, the question was aimed at the OP really. Unless the head as been overheated really badly there should be enough material to skim more than once.
Posted 28th Apr 2009 at 17:38
focuson18s
First I would like to thank everyone for there replies and second Checked the engine code and its a XU10J will change the pistons to GTI-6 ones as a said be gentle I am new to this lol so how much should I pay for a set of Pistons and also from my first topic does that seam the most logical reason for the car not running.
Thanks StewartBig grin
Posted 29th Apr 2009 at 04:52
focuson18s
Head has been checked buy the engine rooms in Motherwell and there is not enough material to get a good flat skim so i will reaplce the head and be on the safe side rather than having to double up on head gaskets.
Best advice that I have been given so far.
Thanks Stewart Big grin
Posted 29th Apr 2009 at 04:54
birk
The gti6 engine code is xu10j4rs, make sure you have this one
I'd just get a complete new engine and swop the thing over, you will know whats what then and you wont have to f*ck around rebuilding it
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 29th Apr 2009 at 22:11
miles
Looks like a XSi head too as with the cam carrier's fitted there's no lugs for the coil pack's, The GTi6 has RS Cast/stamped on the end of the head, Also the std gasket is a MLS item and not like the one shown
www.pugracing.com
Posted 30th Apr 2009 at 05:55
jonnie205
yes its an xsi lump, how were the coil packs held in? however i have seen dished pistons on RS engines
Posted 30th Apr 2009 at 16:19
focuson18s
What power should it produce
Posted 2nd May 2009 at 23:12
it wont be far off the power of a standard gti6 if it has the cams manifolds and management.
head does look like a gti6 one, but someone has obviously put some thought into building it as the cam sensor is fitted, the hole isn't drilled and there isn't a bolt hole either on the XS/XSI heads.
Posted 2nd May 2009 at 23:24
Deffo not an RS head, no lugs for the coil packs and no slot for the vacuum pump too....No
Posted 4th May 2009 at 00:00
focuson18s
Where should I find the engine code for the block and also is there any numbers or code's that i should look for to check the head or the block if so where are they?
Posted 4th May 2009 at 15:42
smegal
The head should have RS cast into the side. Not sure about the block.
Ex SC-6
Now in a Megane R26
Posted 4th May 2009 at 16:27
doesn't matter much at all if you're going to mod it, set of forged high comp pistons and some cams and you'll be sorted Smile
Posted 4th May 2009 at 16:34
xav
where abouts in lanarkshire are you mate?
i must be practically next door to you!
did ye aye?
Ex Spoox/Trac Prep GTi6 16v turbo - the money pit
Posted 8th May 2009 at 01:41
focuson18s
I Stay In Bellshill, what colour of 6 do you have?
Stewart
Posted 8th May 2009 at 14:20
focuson18s
Update 08/05/09
Well Quick Update The previous Head has had it so to the scrap pile, managed to source a head off of a member on hear thanks Fireman01,
So some more pics or the new head
[list]Picked up new Timeing belt[/list]
[list]Picked up new head[/list]
[list]Pland for sunday to get the car built up and running (fingers crossed)[/list]
Thanks Stewart[/list]
