Author Subject: Power steering stiff at slow speeds
justinaccurate
Following on from my "its broke" moment - I think it is broke
Whats happening is when turning the wheel at slow speeds, there is an initial stiffness before it turns normally, seems to happen turning both ways.
Not really sure what to look at; theres plenty of fluid there (though it seemed very thin and didnt smell of anything - i had to put new stuff in the last car and it smelled lovely) and its not making any unusual sounds (my last car had a leak in the hydraulic pipe and it sounds awful when empty lol)
I do suspect a problem with my top mount - the knocking has gradually got louder and im wondering if this steering issue could be a symptom of that Unsure
I can see people seem to sell the pumps for about 20 quid - if it is this, is it an easy job to swap out? having a quick look it seemed like you dont have to have the manifold off for it Unsure
Any ideas Unsure
Posted 2nd Apr 2009 at 00:38
mabgti
NV motors
hmmm.. my pump went on me the last time this happened! and totally stopped working.
now its happened again.. so i'm open to options too.. think it might be a worn ram causing it too?
does it WHIRR really bad on slow speed full lock too?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 2nd Apr 2009 at 01:08
mabgti
NV motors
hmmmm
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 6th Apr 2009 at 02:54
justinaccurate
It whirs quite a bit when going slow if im being honest. Havent noticed it go stiff recently - weird Unsure
Posted 6th Apr 2009 at 18:45
cress87
My steering felt a bit like that when my front springs broke because they weren't seated properly on the top mount...
Posted 6th Apr 2009 at 18:48
justinaccurate
Thanks cress - thats what i was thinking. The springs are only about a year old but i was wondering what else could be broke - I have a horrible noise going over bumps - off to carls again Sad
Posted 6th Apr 2009 at 18:52
mabgti
NV motors
Dont think its suspension related.. Cos if you rev it more its fine. Plus im runnin coilovers and spherical top mounts!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 8th Apr 2009 at 00:49
spitfire
Sorry for the thread revival but have been trawling steering issues with the search button and this best fits my problem.
Justinaccurate did you solve the problem if so what was it?
My car is booked in on Friday to see if they can find the fault.
If you aint first, your last!
Posted 6th Oct 2009 at 01:12
Bet its the top mount bearings gone. Makes the steering bad and gives you knocking noises.
Posted 6th Oct 2009 at 01:39
justinaccurate
I haven't noticed it again since then to be honest, kinda forgot about this Shut up
Having said that I did have my drivers side top mount and bearing replaced shortly after due to odd noises Laugh
Posted 6th Oct 2009 at 03:49
