Author Subject: TOP END TAPPING WHEN HOT? ? ?
darrellspeed
HI guys and girls,
my gti6 engine has a loud top end tap when hot, i have changed the followers thinking that should solve the problem but it still gets the same problem when its hot, has anyone else come across this problem, or can anyone suggest a remedy for it?
oil pressure is good on the bottom end, - 60 psi at idle 100 when revving, and the oil is fresh.
205 XU10J4RS by PUG1OFF 236.4 BHP at Northampton Motorsport.
Lets Race!
Posted 28th Mar 2009 at 17:07
matsoki
what brand and grade of oil are you useing?
Built on 25th November 1998... That was a Wednesday..... Thank God it wasn't a Friday!
RIP - Pete Sims
Posted 28th Mar 2009 at 17:18
darrellspeed
using 10 40 semi synthetic as recommended by the engine builder and its castrol magnatec
Lets Race!
Posted 28th Mar 2009 at 17:19
chas
What filter are you using?
Oh, and have you checked the tightness of your Spark plugs? If you have a torque wrench that you are sure is not out of sync, you can trying checking the tightness with that.
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 28th Mar 2009 at 19:47
smegal
Is it deffinately at the top?
You able to get a video or sound recording?
Ex SC-6
Now in a Megane R26
Posted 28th Mar 2009 at 19:43
kiwibrick
Thread resurrection,
I'm having the same problem with my 6, motor sounds perfect until the oil temp gets to about 80 then the noise starts quietly then increases in volume until the car is at operating temp, it doesn't get any louder when the oil temp goes up over 90 while sitting in traffic.
I changed the oil and it made no difference (unknown oil from previous owner to Castrol by me).
It sounds more like a dull tok noise on mine rather than a tap or tick.
Can't hear the noise over about 2000rpm, it seems to blend away.
I haven't checked the spark plugs yet either
ph2 GTi-6
Posted 14th Sep 2009 at 05:29
fletch
Track Head
As said could be loose spark plugs, injectors or previous interference between pistons and valve(s).
Posted 14th Sep 2009 at 14:33
rallyeca
Had a similar problem when trying some mobil oil 10/40 last summer. If its an older engine might also be worth trying some slightly thicker oil
Rallye for sale!
Posted 14th Sep 2009 at 15:15
hmm, I'd try some total quartz 4000 or 7000 in there, I don't think pug engines like magnatec much.
Posted 14th Sep 2009 at 15:28
Most likely a loose spark plug - usually the one closest to the cambelt.
Posted 14th Sep 2009 at 15:36
kiwibrick
It was a loose spark plug, 2nd in from the cam pulley end, I don't know if that is no.2 or 3 cylinder
ph2 GTi-6
Posted 16th Sep 2009 at 13:23
