Author Subject: No Aircon, PAS moved AUX belt length?
jungle jim
Afternoon!
Well I want to get my PAS relocation kit in place and need to figure out the belt length I will need.
I am moving the PAS down to where the AC was. With nothing up top to make room for my Jenvey's panel filter.
So using this diagram... (Thanks gti6pugbug)
The path in red would be the correct layout? Does anyone know what the correct length belt would be?
One extra question... where would I obtain a belt the correct length?
Thanks!
200+ secret squirrels hiding under the bonnet with 4 wide mouth frogs...
Posted 18th Mar 2009 at 18:29
rich_w
Yes, that's correct Yes
Any decent motorfactors should be able to do a belt if you tell them the lenght.
It doesn't have to be overly accurate, the auto-tensioner can compensate for 10mm odd of belt length
Contact Details:
07732 822546
Posted 18th Mar 2009 at 18:35
jungle jim
Thanks Rich, I'm going to have to do it then go to the motor factors on foot aren't I Big grin
Posted 18th Mar 2009 at 18:38
anth
Trial and error really mate.
I did mine with some rope and took that too a shop
Posted 18th Mar 2009 at 18:39
jungle jim
Yeah, I was going to do the same, except I'm cheap and will use string Big grin
Posted 18th Mar 2009 at 19:09
jungle jim
Well, after finally biting the bullet and believing it won't rain I sorted this on Saturday.
Skinned pretty much every knuckle, and the back of my bloody thumb, but its all now fitted... had a bit of a mare with the pas pump inlet... interference fit... yeah... welded more like Big grin still it moved, and skinned me again.
Turns out the belt I had on there was a perfect fit. It's bloody close between the belt going round the tensioner, and the belt coming down from the alternator -> pas pump. But I've revved it and idled it, and all sorts and it hasn't touched.
Anyway, thanks for the kit Rich!
Posted 6th Apr 2009 at 14:12
rich_w
Glad you got it fitted alright Jim Big grin
Good to see it actually works, I think you're the first person to use the PAS relocation kit from the SC Kit to benefit your TB conversion and get the PAS pump out the way Thumbs up
I wouldn't worry about the belt being close, even if it does touch momenterily it would be ok, it's not like it's a toothed belt or anything.
What length belt did you end up using?
Would be handy to know, there are a few people who are intending to use my kit for ITB conversions.
Smile
Contact Details:
07732 822546
Posted 6th Apr 2009 at 21:18
jungle jim
My setup was switched to a rallye setup after my aircon was removed. So I would expect it to be the rallye belt length... unless they vary quite a bit? i can measure it later...
Posted 6th Apr 2009 at 21:26
Did you ever get around to measuring the belt bud? As I'm in the process of doing the same thing myself and have bought 3-4 belts now that are all too long or too short. measuring it with string seems to have given me an inaccurate result as the string sits right down in the bottom of the Vees and throws the results out.
Posted 21st Apr 2009 at 00:38
darrellspeed
SURELY YOU COULD JUST USETHE S16 BRACKETS FOR THIS AS THE PUMP IS LOWER? THAT WAS MY PLAN ANYWAY.
205 XU10J4RS by PUG1OFF 236.4 BHP at Northampton Motorsport.
Lets Race!
Posted 21st Apr 2009 at 17:57
Thread from the deadWink
So your rallye belt tensioner worked ok with this?Thumbs up
Any other suggestions/tensioner set ups that people use with the relocated pas pump greatly appreciatedThumbs up
Posted 1st May 2013 at 21:05
For anyone else that searches for this you need a 6pk1103 beltThumbs up
How the op's rallye belt fitted I do not knowDunno
Posted 29th May 2013 at 19:43
