Author Subject: Removing seat covers
chris_rallye
Pug CD Master!
My seat seems to be wearing on the door side of the base of the drivers seat. Does anyone know if it's possible to remove the cover to repair it? If so, does the seat need to come out or can it be done in situ?
Posted 4th Mar 2009 at 17:34
jim01uk
BUMP
Posted 13th Feb 2010 at 23:32
fozzy_255
I think that you can remove the base of the seat (cover and foam) by undoing a few screws from beneath the seat. I would suggest taking the entire seat out to have a look though.
Posted 14th Feb 2010 at 14:50
brendanm
There are also a few wire "hooks" that are used to tension the cover. Once these have all been removed, lift out the base from the seat and peel the material off. I spent an afternoon removing seats and trying to swap the passenger base with the drivers, either the whole base or just the material but they are not identical due to the locations of the fittings to the frame. Sad
Posted 20th Feb 2010 at 03:45
dunebugs
do peugeot do replacement covers for the seats ???
Posted 26th Oct 2010 at 21:13
craigy_87
pics from one of the threads i started asking a question about the seats
Posted 26th Oct 2010 at 22:51
smegal
Anyone fancy making a definitive FAQ?
Ex SC-6
Now in a Megane R26
Posted 27th Oct 2010 at 04:20
bennn
You can remove the seat covers, i managed to get hold a brand new replacement of ebay for only £15
You will need to remove the seat (which is the easiest part anyway!)
You have to take the base off then around the edge of the seat you can unhook the cover.
There will also be some wire loops (best way i can think of describing them) which attach the seat cover to a wire which is embedded in the foam - these need to be prised open (i used pliers) and then back together again.
Its easy to see what i mean when you start doing it but it is a very fiddly job!
Cherry Red 306 HDI
Posted 27th Oct 2010 at 15:29
dee dee
Raising this thread again:
Just changing mine now (broken seat frame).
The base is p1ss easy, but the back is a different matter due to it being a cloth seat and mine being ½ leather/alcantara.
Questions -
1. How do you neatly remove the seat latch (allowing access to the rear of the cabin)
2. The headrest sockets (undoable via pushclips) - are they easy to get to?
OR
to make life easy, is there a way of removing the entire back frame for mounting on a new base?
Dan Big grin
Trying to re-install NEATLY.... Bit difficult (& f'in cold!!)
Dan
Posted 27th Nov 2010 at 17:35
BrianM
Anyone else had any luck with this??
'13 208 Gti Bianca White, '99 Bianca 306 Rallye, '92 309 Goodwood GTi 5dr, '92 Miami Blue 309 GTi 3dr.
Posted 12th Mar 2012 at 23:05
russbez
i once made a complete tit of taking one of these seats apart, (a spare rallye one i had, it was already wrecked)
wouldnt fancy putting one back together
had a professional redo my Rallye drivers seat when Vinyl was passed its best
My Rallye project thread
Posted 13th Mar 2012 at 11:15
russbez
i think he means Hog rings, there a common thing that fabric retrimmers use
you can buy them, and a tool for doing them iirc
Posted 13th Mar 2012 at 11:18
mik
Hog ring pliers - they have a notch cut out to put the hog ring into.
See the Hawg Ring Lunge for info on reassembling seats (it is a guide for an Audi quattro but the principles remain the same).
And an ebay listing for hog ring pliers including 100 hog rings.
Cherry Rallye SOLD
Posted 13th Mar 2012 at 16:52
BrianM
Ah right, cheers Russ, I might still have a go and destroying my own destroyed rallye seat and see how i get on or if i can salvage any of the good bits from it. Some of the material is fine, seems most of the destroying is on the material side? which is daft? Not worth throwing away yet anyway...
Posted 13th Mar 2012 at 23:36
mik
Wow, someone with a big heavy @r$e must have slid down that a few thousand times to do that sort of damage.
Cherry Rallye SOLD
Posted 13th Mar 2012 at 23:51
BrianM
It's mental eh? The seat that's in there now is also pretty damn worn. No tears but I can feel the braces under my arse on the seat, which is super uncomfy! The bolster foam seems pretty good, which is odd. He must have liked trousers with buttons on them and that tied in with a heavy arse motion into the car will have done the trick. It's some job though to tear BOTH sides of the bolster though eh? In fairness though to these seats...peugeot make comfy seats now but when they made the 306 seats, they didn't design them to be hardwearing did they?! lol.
Posted 14th Mar 2012 at 00:03
russbez
Hehe the spare one i had was the same, the foam was destroyed
Posted 14th Mar 2012 at 09:12
BrianM
I have fetched my seat from the lock-up and brought it to the garage at my house for further inspection...rather heavy seats eh! They don't look like much either.
Posted 15th Mar 2012 at 23:18
russbez
aye they arent that light eh
planning taking it apart then?
should take lots of pictures, for your own reference really LOL
Posted 16th Mar 2012 at 12:43
