displaying posts 26 to 50 of 320
Pages (13): 1 [2] 3 .. last
Author Subject: Project Money Pit Rallye (Pic Heavy)
ahhhh feels nice to be back on the forum. since its been down ive been a rather busy bunnie collecting parts and painting like crazy!!!!!
also took my old engine apart with intensions to just change the stem seals.............until i noticed the waterjacket on the gasket was soon about to go so i then decided to rebuild the whole thing. having great fun tearing it apart with paul.
rallye wise i replaced the beam with my beam tube that has ok bearings and took the 21tbs out because one of the end bolts had snapped!!!!!the car is now sat on its ass till i sort this :LOL took her out for a spin........noise coming from the front end.......ahhhh topmounts......ah missing washer for top mounts,ah well got mine at home. then noticed its unsettled when putting you foot down.......hmmm play in rack ahh also ball joint not the best so wack them on order. radiator pressurising???????? rebleed sorted it for the mean time but green coolant???????
then fitted my nice fresh carpet in the rear and fitted my new boot badge and didnt touch her for a week.
feeling good Smile........................................................until yesterday went for a 50mile drive with my mate paul (because he is bedding in fresh engine rebuild) bugs everywhere so had to spray the window clean........wind window up as you do and put cold air fan on.........nice fuel smell!!!!!!
cams run lean so dont worry. then found and lovely road at least 7miles long which is just awesome so i fought "lets see what you can do" f*ck ME was great the rallye just pulled then went all boggy and odd..............pull over pop the tank.......................................................................................................
f*ckING HEADGASKET Angry
so have now knocked the rebuild on the head because i have to take the hire car back soon and will need the car for work Sad just hoping once the head is done the bottom end wont go.
cheers miles for attacking the head so quickly and thanks paul for all the help an for dropping it off for me SadSadSadSadSadSadSadSadSadSadSadSadSadSad:
Posted 10th Sep 2011 at 21:15
paul_13
No worries, was a last moment thing dropping the head off.
Been a while since i've seen you that angry LOL
Hopefully we get the head back soon Smile
Now mine is in pieces again f*cking oil leak
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 10th Sep 2011 at 22:01
FRENCH haha
Posted 10th Sep 2011 at 22:12
7057sam
hovis what cage have you got.i've been trying to find 1 with no side bars
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 11th Sep 2011 at 23:30
its an omp one with the side bars not fitted i think
Posted 12th Sep 2011 at 15:36
so another day attacking the rallye, woke up and decided to rip the fans and rad off because the headgasket had gone. nice enough everything came off nice and easy.
once i had this all out i noticed some rust so i attacked it with the wire brush and sander and krust and then painted it all back up.
while i was at it i sanded and painted the front brakes and took the wishbones off to replace with mine
before attacking the wishbones i put some new ball joints on mine
then the problems started........first was the trackrod end which refused to some off.......so i hacked it off then the droplink did the same....so i hacked it off then noticed both ball joint pinch bolts were over tighten lucky enoungh the hubs aren't ovalled. so i moved to the front of the car again and decided i dont like the one fan set up on the rallye so..............
after hacking the six on apart i now have a twin fan set up. one fan will be a manual switch while the other is auto.
that done i then turn my attention to the power steering which has be relocated and not fitted correctly. it i ment to fit in to the holes with the shoulder spacers/dowls and guess what.........yeap you guessed it NOT FITTED.because of this the belt makes a horried noise whinning so i thought i start taking it off..................................
whats wrong with this picture??????
Posted 13th Sep 2011 at 21:29
beez_neez_gt
Nice looking Rallye, great project too Thumbs up
Is it a dirty finger trying to touch up an engine with a crack in the power steering pump ?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 14th Sep 2011 at 00:43
its becoming and nightmare oil surface rust and quick job end everywhereThumbs down part from that its great hahah
Posted 14th Sep 2011 at 09:23
Shouldn'nt worry much about that crack Marcellus, its held in compression by the two plates of the relocation bracket. Just keep an eye on it to see if it gets worse.
Posted 14th Sep 2011 at 09:43
Post #35
need to take it off to fit correctly,beside steering was heavy and i have a pump from the six.......basically and whole car in the garage lol. oh well on the way to pug for flywheel bolts driveshaft seals repair headgasket and gearbox oilThumbs up
Posted 14th Sep 2011 at 10:05
paul_13
Post #36
Should be around tonight so we can get the head off and see how blown that HG is. Fingers crossed no coolant in the bores.
I'm going to reassemble 205 and I'll be round.
Need to check engine cradle!
It's full of bodges!
Posted 14th Sep 2011 at 13:24
paul_13
Post #37
O dear puddle of water in one of the cylinders Sad
Hopefully blocks not scrap
Posted 14th Sep 2011 at 15:26
Post #38
f*ckED NOT HAPPY
Posted 14th Sep 2011 at 22:27
paul_13
Post #39
Coolant in cylinders 1 & 4 Sad
Coolant in exhaust manifold, collector number 4 is submerged in coolant
Blocks been decked by the look of things
Engines not the original engine. Early pulleys along with the 136t tensioner. Should be a 137t setup being a t reg.
Posted 15th Sep 2011 at 11:48
Post #40
Sorry to hear this Hovis Sad
Posted 15th Sep 2011 at 11:56
paul_13
Post #41
He's not in the best of moods to say the least.
I'll get some pics up later.
Turning out to be a full car rebuild, dropping the crank off with Miles when we get the one out the rallye. The one out of the gti6 was a little scored, so see which one looks best as it'll save on a regrind
No wonder it was down on power!
Posted 15th Sep 2011 at 12:00
cwspellowe
Post #42
Bad news buddy Sad
Bye bye Sundance Kid Sad
Posted 15th Sep 2011 at 12:19
Post #43
I assume you have a spare engine from the old six mate? Was that engine all good?
Posted 15th Sep 2011 at 12:37
Post #44
yeah the six engine was good but had a bit of puff whenever you booted it.....stem seals so we got carried away and ripped it apart to rebuild then put back in and then sell the rallye engine No to make some funds back but thats not happening now.No on the bright side of things lightened flywheel is on the way with new seals oil pinch bolts number plates and loads of more stuff.
she'll be a beauty when we are done with her quick to. good thing also is...................havent fully paid for the car yet LOL i think that enough for now
Posted 15th Sep 2011 at 12:45
Post #45
f*cked engine cradle
Posted 15th Sep 2011 at 21:24
Post #46
Man, I really feel for you. I genuinely don't know why we do this to ourselves. You'll get it sorted, don't worry Thumbs up
Posted 15th Sep 2011 at 21:40
paul_13
Post #47
Engines out now, will be stripping bottom end later.
Upper engine cradle is cracked aswell, mounts swinging about pretty bad.
Posted 16th Sep 2011 at 11:00
Post #48
Sooooooooooooo the rallye lol the engines out and completly dead. cranks had it heads had it blocks had it powersteering pumps had it gearbox mount has had it engine cradle has had it.........but on the bright side cams are fineSmile pauls going to pick my head up tomorrow and my parts and oil have turned up at pug.......costing abit and the misses aint happy. will post pics of the carnage so. COOLANT IN THE EXHAUST MANI??????/ How the f*ck???
Posted 16th Sep 2011 at 21:34
Post #49
easy, gasket gone LOL
Posted 16th Sep 2011 at 21:37
paul_13
Post #50
Heads warped like a banana
Crank's quite scored,
Oil sprocket has 3 teeth missing
You can see the tide marks of coolant in 2 of the bores
Power steering pumps cracked
Coolant in the exhaust manifold
Engine out
Posted 17th Sep 2011 at 00:18
