displaying posts 276 to 300 of 320
Pages (13): first .. 11 [12] 13
Author Subject: Project Money Pit Rallye (Pic Heavy)
Post #276
Seems some of the bits turned up quicker than expected.
Bye bye wobbly 8 yeah old bearing
Refitted and adjusted to stop it tapping the heatshield in 3rd and 5th.
Also after seeing Tom fit some standard B Pillar vinyl's I decided to fit some non standard looking ones Shock the car is far from standard now to be fair
Hopefully the weather holds up or I can get hold of the easy up to tackle the clutch nextThumbs up
Posted 13th Aug 2020 at 13:40
Post #277
WA7ER wrote:
Is this the same Rallye that I've seen around HP / Cain Road in Bracknell a few times?
Cracking looking car, I'm taking notes for my own Smile
That be me on the way to work in Windsor/ Winkfield Thumbs up give us a honk next timeLOL
Posted 13th Aug 2020 at 13:49
S8-Tom
Post #278
Looking good as always!
B pillar glue is a bit of a faff to get off and I struggled lining-up the new vinyl but they look great all fresh and new.
Posted 13th Aug 2020 at 15:41
Post #279
mine were never fitted so was easy. in terms of lining up...…………………………. yeah the top and both line up and that it hahahahaha
LOL
Posted 13th Aug 2020 at 16:03
Post #280
LOL So after taking the car to Corwall she seemed to acquire a few issues No Sad
1) Squeeking under revs not all the time but only in the lower gears.
2) Creaking from the front under load on on off power (engine cradle Thumbs down )
3) Juddering in low revs under 2700rpm and it would kangaroo like madeUnsure
4) Struggling up hill...….. these were Cornish roads
5 Bang/ knock from back end. Sometimes braking and sometimes pulling always.
So all in pretty much not a very happy girl, So in typical Hovis fashion I can carried away and attacked the car for the 3rd time this year LOL removing the Gearbox was on this occasion nice and easy and thankfully no gearbox issues.
Clutch removed the Flywheel seemed ok Even after the Inlaw tried to move it when I was away resulting in burnt clutch smell everywhere.
Thrust bearing on the other hand was shoot. (1) squeak noise found so replaced this along which the clutch.
Noted the Red spring was a completely different length on the new one but after checking several time I can confirm this is correct, I assume a newer one.
Next was a check of all the bolts around the engine area. Removal of the Lower mount point resulted in finding the BM Lower mount was sliding out of it metal sleeve Shock so replaced it for a Vibratechnics one instead (2) Juddering solved
Next was double checking the drive shafts...….and you guessed it shot Intermediate bearing so binned that and all (4)
I then found a genuine cat so got that Purchase asap. Found small hairline crack so double checked it all and got It welded up.
With that all done popped it all back together checked it and tad most noises gone. Still getting and knock from the back which I assume may be due to engine movement but I removed the rear passenger brake to double check put it back together and the noise has gone...…………………………...Dunno for now. In the process I did thread a wheel nut slightly Whistle so that need a replacement hub heilcoil or stud nut conversion.
withthat all done the next thing was a bit more tarting up LOL
Love
With that all done I finally wired the wife's heated seat in and now getting ready to finish off wiring the window in.
ThatsThumbs up all for now
Posted 25th Aug 2020 at 14:30
Post #281
Fantastic update ...well done Thumbs up
Keep um coming
Posted 25th Aug 2020 at 19:25
Post #282
Keep um coming
How’s that heated screen ?
Not connected up yet Roll eyes
Posted 26th Aug 2020 at 20:22
99rallye
Post #283
Yeah, nice work Hovis
Posted 27th Aug 2020 at 07:00
Post #284
Another small update.
After managing to strip a wheel nut I thought id take the plunge and buy a stud nut conversion, as the wheels are always being taken off I thought may as well.
I purchased 68mm length Satchell studs of which im very happy with the length fitment and quality.
and as you can see with the Trunnies fitted lenght is spot on,
I then got rather excited about an upcoming Trackday so I went on the hunt for "SOME" tyres and got a tad carried awayLOL LOL
The yokos where brand new so that purchase was for more of a summer driving tyre but, in the process I found a nicer set of wheels than my old 5 spoke LR-01R so I got another set of Speedlines Love
These came fitted with some Dunlops as an extra added bonus..........hope its not a wet trackdayWhistle
Apart from that I purchased a alloy thermosate housing from Blackmamba that I will fit shortly
nice bit of kit should stop the weeping from mine as is split towards the top.
Thats all for now.LOL
Posted 11th Sep 2020 at 08:57
Post #285
Nice update Thumbs up
Good luck with the track day
Posted 11th Sep 2020 at 18:35
Post #286
So finally managed to get some work done on the car,
First up was fitting the Thermostat housing as mine was worn and had been leaking for a while.
To my disappointment after purchasing a new thermostat and seals it still was weeping between the housing and body No
After further investigation I found the main body had a couple of grooves allowing fluid to bypass so a tiny bit of sealent resolved that.Thumbs up
Next thing on the agenda was to wire up the window and fit a new switch which I must say looks rather nice Love
Only thing is we did manged to switch the wire by mistake so that will be finished off tomorrow Thumbs up
Finally manged to hit the 190 thousand mile mark, so that's 80 thousand miles since the rebuild. Engine wise going on strong...………………………...everything else no so LOL LOL
As I finally have found someone close by to weld and finally have the car booked in I turned my attention to removing the interior.
Upon removal I decided to remove the front sound deadening Shock which was a good idea.
Luckily all it was is surface rust so I attacked it and the coated it in Hydrate80 then zinc primed and topped off with black hammerite.
With that complete for now I turned my attention to preparing all of the metal work for welding. The engine mount No pretty much gave in on the way for a quote which was great timing Thumbs down Thumbs down
Thumbs down
The front cage brace bar was also attacked as I noticed it had cracked when fitting the new window.
With that sorted I then decided to sort out all of the required plates I will need and drilled another 4 holes in the foot base as they were all only mounted with two boltsAngry
I also decided to nick an idea from Dennis (Russianguy) that I have been meaning to do now for a while
So for now finger crossed the welding will all go well on the 29th then its off to Brands on the 2nd Cool
Posted 24th Oct 2020 at 18:43
Post #287
So Managed to get the cage plates and engine mounts welded in.
not the greatest job as they are awkward spot and thin metal but all in feeling solid for now
Didn't manage to get any of the mount and also didn't end up doing the side plates in the end.
With that I popped the interior back in and purchased something for those early mornings LOL
All done and good for brands hatch Thumbs up
A very wet day to start with which then resulted in it being very dry and very fun with a load of us on the track Love This also ment the Semi slick came out and oooooooooo my what a difference they make once warm LOL I did only manage three slides which were all great fun and controlled rather when what can only be due to my set up and noting to do with my driving LOL LOL LOL LOL
Love Love Love
Over all a great day that has warranted so more upgradesLOL
Posted 12th Nov 2020 at 16:04
Joep
Post #288
Nice pics!
Need to join you all once we are able to travel again!
The holes in the front bumper, do they really make a difference? Was thinking of doing the same...
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 12th Nov 2020 at 16:19
blandy
Post #289
Looking good, Been following the pics on fb looked a good day out at brands certainly nice to see so many 306’s on track as but if a rare sight nowadays
Posted 12th Nov 2020 at 20:05
99rallye
Post #290
Awesome progress, the cage and floor looks so much better. I love the pics from Brands looks like a brilliant day! How did you find out that there was a 306 meet up? Once mines back in one piece I'd love to come along😁
Posted 13th Nov 2020 at 06:55
Post #291
We all discussed if on Facebook after Greg mentioned he was going and then pretty much booked it, after speaking to Greg and Aaron I think we are going to do it again in the new year but this time I will try and mention it on the forum instead of Facebook AND GET A LOAD OF US OUT Thumbs up
Posted 13th Nov 2020 at 10:27
Post #292
Joep wrote:
Nice pics!
To be fair I did it because "race car" LOL but it seem to work very well as I don't use a oil cooler and the temps always seem to do very well. I am running titan s 10 50 fully synthetic so that maybe whyLove
Posted 13th Nov 2020 at 10:30
Post #293
Love the updates and Brands day WOW !!!!!!
Keep the updates coming Thumbs up
Posted 13th Nov 2020 at 12:39
Joep
Post #294
hovis16 wrote:
Joep wrote:
Nice pics!
"Because race car" convinced me Wink I am also thinking of removing the lower part of the rear bumper to reduce drag. Have the damaged one from when the BMW hit me as spare.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 13th Nov 2020 at 13:28
Post #295
So following the Brands trip I decided to do some upgradesLOL
First was a 28.5mm arb
Should make for epic turn in and twitchy bum moment on bumpy B roadsLOL LOL
I then managed to get hold of the last set of these bad boys Love
To help with this I purchased a new set of adjustable rose jointed Droplinks and new Arb bushes to fit well Roll eyes
Posted 13th Nov 2020 at 17:07
eiei0
Post #296
Looking good,
The Subframe cups landed as well during the week Thanks for that,
I'm slowly getting to work out who is who from here and Facebook Big grin
Thanks
Trevor
Posted 13th Nov 2020 at 19:53
Post #297
eiei0 wrote:
Looking good,
Thanks
Trevor
Glad you got um mate
Posted 13th Nov 2020 at 20:22
Post #298
So finally managed to get the new arb and wishbones on,
Also got some adjustable droplinks that I need to play with.
Had a bit of a mishap while fitted which resulted in a damaged set of bearing due to the shims not being located correctlyNo that was not fun at all. But after resolving this I can confirm the cars a different beast. The turn in and grip is ridiculous but...……… as my part worns are past it in the damp it is VERY twitchy so In typical hovis fashion
I got another set of PS3S Love
that's all for nowThumbs up
Posted 4th Dec 2020 at 10:28
blandy
Post #299
Can’t beat ps3’s for all round by far best all round tyre I’ve used.
What torsion bars you using with the arb?
Posted 4th Dec 2020 at 19:32
Post #300
Using 21mm bars. The turn in is amazing
Posted 4th Dec 2020 at 22:55
