Author Subject: Coilover spring Rates
I'm running 200lb springs but apear to be too long at 9" i have them as low as possible but the springs keep banging together
I'm going to be changing to 6" springs
but don't know weather 6" springs 200lb and compressed about 1" would feel ok for road use or to go 300lb or is that too harsh?
is there a table to give an indication of
how harsh the ride is dependent on weight of 6 Vs ?lb of spring? Confused Geek
Posted 30th Sep 2010 at 22:39
cooper666
ive got 250lb springs 8 inch lenth non or very little pre load and there going coilbound aswell would like to know aswell got some 325lb to try on the weekend
clio r27
ps3 id:cooperkloe
Posted 30th Sep 2010 at 23:45
Denis
On a standard 306 GTi front corner weight is about 370kg ~ 800lb.
So 200lb spring will be compressed 4” with the car on the ground. This means that it is impossible to use 6in 200lb spring on the front. For 9” free length spring you have total travel of ~5.9”. This means that the suspension goes coil bound after only 1.9” of travel.
For 250lb springs: compression due to weight of the car 3.2”, 8” spring has total travel of ~5”, so again very little suspension travel.
In both cases the springs are too short for the weight of 306. If you want to keep the spring rate the same it would be necessary to go for longer springs and to make sure that when they are close to going coil bound the bump stops come in to play.
As for increasing spring rates – it depends on the kind of driving that you do and how well the dampers can cope. Standard front springs are only 110lb but have a lot of preload.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 1st Oct 2010 at 04:54
That's some helpful info cheers Wink
I'm after the car sitting at -45mm / -50mm
I don't drive like I stole it or anything but do sometimes run 17" wheels so just looking for something not too harsh but not have the spring going full travel on standard pot holey roads Dry
Posted 1st Oct 2010 at 05:59
I was using 285 on the ASTs for road use although not sure on the length. Perfectly acceptable ride I thought but they were fairly well damped. Didn't bottom out once the rear damping was sorted and was sat at about -45mm
Posted 1st Oct 2010 at 13:41
I did have in mind "6 300lb Coilovers so I shall give them a shot! Big grin
Posted 1st Oct 2010 at 18:39
you'll need a lot longer than 6".
Posted 1st Oct 2010 at 23:19
cooper666
just fitted the 325lb 8 inch springs and now sits and rides perfectly compared to the 250lb. just need to lower the rear slightly and then set the ride height to give it a proper test.
clio r27
ps3 id:cooperkloe
Posted 2nd Oct 2010 at 00:20
Like I say I have 9" ones compressed to Max still sits 1.5" / 2" too high
7" should be ok then?
Cooper Have you taken any pictures profile pix
so I can see the ride height with your new settings Big grin
Posted 2nd Oct 2010 at 00:44
cooper666
new ride height is set to about 20mm lower than standard on the front but my coilovers could go alot lower theres still 3 ½ to 4 inch of threads left .only want to go-30mm all round for time being but need to sort rear axle out first.
will add some pictures next week but are lass has just took the 6 on holiday with her for the next week.
are your springs 2 ¼ id if so you can try my 8 inch 250lb ones if you like you might have more luck than me with them. think my problem was that my coilovers are designed for 30mm [avo]drop minimum and i had them set at about 15-20mm didnt want to run to low at the front until rear was sorted.
clio r27
ps3 id:cooperkloe
Posted 2nd Oct 2010 at 00:58
You let your Girlfriend drive off in your car Mellow expect that to come back broken LOL
unfortunately I have a 2.5" ID I'm going for 300lb 7" Springs they should see me right! touch wood! Smile
Posted 6th Oct 2010 at 18:10
cooper666
it hasSad
clio r27
ps3 id:cooperkloe
Posted 7th Oct 2010 at 00:47
laurentgarnier
laurentgarnier wrote:
cooper666 wrote:
it hasSad
Doh Ban
The Leveller
Team China™
Laurent Garnier "The Man With The Red Face"
Posted 7th Oct 2010 at 03:42
phil b
cooper666 wrote:
it hasSad
Doh Ban
Spose it doesn't look as gay a female drivin a manstone Whistle
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 20th Oct 2010 at 15:24
pinkfloyd
I run 450lb springs on my Avo coilovers for track use.
Liverpool Motor Club Sprint champion 2017
Longton & District Motor Club Sprint champion 2017
Liverpool Motor Club Sprint champion 2016
Liverpool Motor Club Sprint champion 2015
Lancashire & Cheshire Speed Championship
Winner 2014
2nd 2013
Winner 2012
2nd 2011
Winner 2010
Winner 2009
Winner 2008
Winner 2007
2nd 2006.
Posted 16th Nov 2010 at 17:58
im not very good with spring rates...... am i right in saying 225 7" spring with standard bars and an hybrid arb will work right? anything harder will be to harsh for the rear? only going to use for track couple times a year and want to make sure i get this right
Posted 7th Jan 2011 at 16:19
dj_turner83
I know this is a few months old but wondering if anyone can help... I have cheap raceland coilies on my HDi (I kno I know, but they wear a gift so can't complain too much, plus IMHO there better than the Gmax Shox and springs I had on before them).
basically I want to change the main coil springs as it's far too compressed and goes coil bound to easily but don't know what spring rate to go for and if I should have longer springs and loose the helper??? here's some pics to help:
these pics are the car as it stands under its own weight:
Jacked up so the wheel no long touches the floor:
Cherry 306 HDi Stage 1 Remapped
Smooth Bonnet & Grille
Lowered -40mm
Posted 11th Aug 2011 at 21:28
Have you tried the tie-wrap trick yet? Wink
Posted 11th Aug 2011 at 21:34
dj_turner83
Haha, you found me, I have a cable tie in my pocket now and will wrap it round a coil before I leave work, then I have a 50min drive home before I give you an answer.
from reading what Russian Guy wrote (post #3) it seems longer springs is a must. I just want it to hit the bump stops before going coil bound (which I'm sure is what its doing as the coils are marked top and bottom)
As you can see in the first pic of post #17 regardless of the spring there isn't much travel left in the shock itself and my car isn't as low as Mary_Aireys and DarrenjLobb and there on the same kit, I don't know how they manage. the top of the tyre isn't in the arch like some and there 55 profiles:
Lowered -40mm
Posted 11th Aug 2011 at 22:37
Darren's does suffer from massive lack of traction and compliance in his video's though, so maybe they're just putting up with it for the looks...
