wayne mcardle
Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Twangy
Senior User Location: heswall Registered: 27 Jun 2014 Posts: 623 Status: Offline |
Post #1801
looking good damien , ________________________________________ wayne mcardle |
Posted 16th Feb 2018 at 21:21
Post #1802
quote: [quote="Twangy"]looking good damien , Thank you Wayne .... How’s yours coming along m8 ? |
Posted 17th Feb 2018 at 05:38
Post #1803
Small update ...Pic is looking from back box to middle box towards engine had my 2.5 exhaust modified in a earlier post to straight pipes and straight out the middle / back now .... In the picture you can see the sunk in ATL grey Alloy fuel protection box on the left of the Exhaust with Zircotec3 silver on the side of the box ...1inch gap I’ve welded a stainless steel bracket across the middle box and fixed it on two rubber bobbins to elementate to much movement ..the Engine doesn’t move anyway The Handbrake cables aren’t connected and are hanging in the picture Day666 has attached the following image: |
Posted 17th Feb 2018 at 17:36
Post #1804
This is the back box looking from the middle box towards the rear of the car just in case it’s difficult to see ......Pipe is bent up around the rear beam to get the rear box up high off the floor ..As ROSS just said more Zircotec3 going around the beam tube and more on the tunnel and more on ATL alloy protection box to keep exhaust heat totally away ..exhaust is 2inches from the beam but it looks like it’s touching on this pic Day666 has attached the following image: |
Posted 17th Feb 2018 at 17:54
Post #1805
You can see the rear box ...extra stainless brackets welded on and then fixed to rubber Bobbins also to elementate movement and extra safety in case one Red hanger gives up the go...The hole in the floor with cardboard covering above the rear box will be filled in ...it was where the old battery box was Day666 has attached the following image: |
Posted 17th Feb 2018 at 23:48
Post #1806
Well here it is !!!!!!OMFG My ultimate item Day666 has attached the following image: |
Posted 18th Feb 2018 at 19:58
superchargedblack1997gti6
Post #1807
Yes yes yes nothing left to buy . You have now created a monster. ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Posted 18th Feb 2018 at 20:01
Post #1808
quote: [quote="superchargedblack1997gti6"]Yes yes yes nothing left to buy . You have now created a monster. Just teasing.....it’s Tonys Sadly |
Posted 18th Feb 2018 at 20:41
Cjwatson27
Post #1809
But it’s so shiny lol________________________________________ Old pugs don't die they just get faster |
Posted 18th Feb 2018 at 20:47
Seasoned Pro Location: The Nam Registered: 24 Jan 2006 Posts: 12,828 Status: Offline |
Post #1810
I'd put a stainless or ally honeycomb heat shield between the exhaust and the fuel tank. The zircotec stuff isn't that great.________________________________________ Nothing to see here |
Posted 18th Feb 2018 at 21:06
Post #1811
quote: [quote="adam b"]I'd put a stainless or ally honeycomb heat shield between the exhaust and the fuel tank. The zircotec stuff isn't that great. I’m sure your aware ...but for those that aren’t ...The Alloy box is only to protect the composite tank inside Adam....The tank that sits inside is a lot small ..ok with fuel expansion it will get closer m8 ... That Zircotec 3 is what they use on Boaing and Airbus tanks ...it has ceramic sandwich Adam ...you sure your not getting mixed up with Zircotec 1 And 2 that’s not Avaiation approved .... I know the silly price doesn’t make it automatically Great ...but I have this already in my Tunnel above the middle stainless box and the floor only just gets warm .... I do have to buy more though and make the area larger .... Remember also my original standard Plastic tank was above 2 inches away on the same but curved exhaust with only the standard fibre Heat shield and Heat always rises ...the tank case is to the side 1.5 inches Zircotec 3 reflects 85% of the heat ...not many can claim that |
Posted 18th Feb 2018 at 21:55
Post #1812
quote: [quote="Cjwatson27"]But it’s so shiny lol Yes and you can have it Any Anodised colour combo to It’s the very last thing I would get and that hopefully will be in the next two years |
Posted 18th Feb 2018 at 21:58
Post #1813
Small update no pics ....managed to fully wire and calibrate the fuel sender ...the easy bit done .....but couldn’t get the same fuel pump to work off the DTA what ever I tried !!!!I changed the relay I fitted and for 45mins or more was pulling my hair out ....until Will said you been welding haven’t you and didn’t you unplug your DTA Dick head All sorted and car started ...exhaust sounds the same as before ...and ATL /pump is mega quiet ..big bonus ...so I’m a happy chappy |
Posted 21st Feb 2018 at 10:58
Post #1814
Another Bonus—— no fuel smell....but there shouldn’t be and car starts first time every time ....so far |
Posted 21st Feb 2018 at 11:01
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
Post #1815
So how did you get your DTA to work then afterwards, did the welding cause a earth spike somewhere and temporarily disable the fuel relay output?.Nice gearbox by the way, saw a sequential 306 box on Mikado Racing classifieds yesterday. 4500 Euro. |
Posted 21st Feb 2018 at 12:57
Post #1816
quote: [quote="RallyeP6"]So how did you get your DTA to work then afterwards, did the welding cause a earth spike somewhere and temporarily disable the fuel relay output?. Nice gearbox by the way, saw a sequential 306 box on Mikado Racing classifieds yesterday. 4500 Euro. I unplugged the DTA loom to the DTA a few days before because I was welding on the car .....I forgot to connect thel loom back up to the DTA ...when I did everything worked again £4500 is the DOG box straight cut gears ....not full Sequencial |
Posted 21st Feb 2018 at 13:54
Post #1817
Small update until a big ish one end of next week On the bottom middle pic ....Fitted my Pro Stack Oil Temperature gauge today that goes green until over set temp and alarm / Red light flashes I know I could of bought a Digital Dash with how much these 3 cost but hey ho Also ....rad fan blade is on the correct way now and blowing into the rad / into the engine . Just got to find a place now for my ATL fuel gauge The switch down on the bottom right is my heated front W/S on/ off Day666 has attached the following image: |
Posted 24th Feb 2018 at 18:51
Post #1818
Rad cover and air Director finished Day666 has attached the following image: |
Posted 26th Feb 2018 at 18:32
Post #1819
Bumper nearly finished apart from spraying ...all the radiator air scoop behind the bumper sorted ...stariting to look like a car Next job to fill in gap from the bottom of the carbon splitter to bottom of bumper ...you can see the alloy box section at mo ....will be filling in the sides ...also filling in either side of the rad / bumper and fitting air ducts through my bumper eithe side to my brakes .... Day666 has attached the following image: |
Posted 26th Feb 2018 at 18:41
Post #1820
Tiny update Made the thin Alloy strip for above the splitter & welded on brackets to fix to the bumper and splitter ...this was fun NOT !!!! Day666 has attached the following image: |
Posted 28th Feb 2018 at 13:55
Post #1821
The shape is up and down and curved so had to play around lots to get a happy fit Day666 has attached the following image: |
Posted 28th Feb 2018 at 13:56
RallyeP6
Post #1822
Wow it looks like a mid nineties BTCC touring car, welding thin aluminium, well done. |
Posted 28th Feb 2018 at 16:00
Post #1823
quote: [quote="RallyeP6"]Wow it looks like a mid nineties BTCC touring car, welding thin aluminium, well done. Thankyou ....but trust me Rouben....the shape to get correct was the hard bit ...thank god for long cardboard |
Posted 28th Feb 2018 at 16:07
Post #1824
More silly money big sheet of Zircotec 3 self adhesive.....for on top of existing stuff and for the rest of the rear tunnel Day666 has attached the following image: |
Posted 28th Feb 2018 at 16:17
Post #1825
Some nice big Alloy (76mm piping) brake ducts to match my Satchell Jenvey Trumpets ....they will fit in my front bumper to cool my Rotors / pads down Day666 has attached the following image: |
Posted 28th Feb 2018 at 17:23
