Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Post #1751
I’ll try and show it from the front ....it’s difficult to take a picture Day666 has attached the following image: |
Posted 4th Feb 2018 at 19:35
Post #1752
I’ve nearly sealed all around the rad apart from a few mm areas ....underneath on top and sides are pretty much firing / direct Cold air to Rad / Oil cooler now .....Just got to Tweek Weld some thin Alloy angled out Mouth type scoops to finish it ...they even come through lower bumper bars for max air suction.... Anything Silver you notice in the pic is Alloy and not finished Day666 has attached the following image: |
Posted 4th Feb 2018 at 19:41
Post #1753
Another small update ...Bonded and used the smallest rivets for my Alloy Cold air grab Angel wings to fix to my Composite Rad cowling...They haven’t been cut down or shaped yet for the bumper to fit so (don’t Laugh) .... Even before the structural bonds dried 24hrs full strength....the thin alloy is stiff as hell ...each side is bent back on each side and fixed to the inside of the Cowling I made at Tony Palfrey place .... The Bumper covers the top section ,..so that’s why a small gap is showing just above and below the Alloy nudge bumper support Im pleased how it’s turning out ....thank god Can’t see from this pic but the Rad front cowling stops all the cold air from escaping around the rad on all 4 corners ...the Angel wings what I’m calling them ....when cut down and shaped will just help trap a little more air Day666 has attached the following image: |
Posted 5th Feb 2018 at 21:06
Post #1754
Sold so much old stuff I had hoarded and needed to get rid of ...even sold spare stuff off my car to pay for this as I just haven’t got money to spend .....I hope it’s in the box ? Day666 has attached the following image: |
Posted 8th Feb 2018 at 16:31
superchargedblack1997gti6
Post #1755
Have fun fitting it . Good work though mate will be safer than you’re old setup________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Posted 8th Feb 2018 at 17:48
Post #1756
quote: [quote="superchargedblack1997gti6"]Have fun fitting it . Good work though mate will be safer than you’re old setup Thank you Ross .....It came 100% all fitted and tested ... Just two wires for the pump and the sender built in already and a ATL fuel gauge making it easier easy x3 anc pipes ive got already there Ross Day666 has attached the following image: |
Posted 8th Feb 2018 at 18:01
Post #1757
All really straight forward m8 ....got all the filler hose off ATL also great stuff ...just got to weld some Alloy angle onto the Alloy ATL box and sink it into the bench seat behind the Passenger seat Day666 has attached the following image: |
Posted 8th Feb 2018 at 18:03
eddy_gti6
Post #1758
Got to love getting shiny bits. Looking good mate ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 8th Feb 2018 at 18:24
Post #1759
quote: [quote="eddy_gti6"]Got to love getting shiny bits. Looking good mate So True Chris ....thank you my friend...what’s your plans now ?...van etc ? |
Posted 8th Feb 2018 at 19:16
blandy
Post #1760
Do you still run a external swirl pot or is everything done in the cell? |
Posted 8th Feb 2018 at 19:49
Post #1761
quote: [quote="blandy"]Do you still run a external swirl pot or is everything done in the cell? Everything Michael done inside the box....3litre swirl pot inside m8 Pump inside and a baffled with fuel level and one way valves also ... |
Posted 8th Feb 2018 at 20:37
eddy_gti6
Post #1762
quote: [quote="Day666"] quote: [quote="eddy_gti6"]Got to love getting shiny bits. Looking good mate So True Chris ....thank you my friend...what’s your plans now ?...van etc ? Not too sure just yet, just want it sorted out 1st since someone has been f**king on with it since last time i had it ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 9th Feb 2018 at 09:50
Post #1763
quote: [quote="eddy_gti6"] quote: [quote="Day666"] quote: [quote="eddy_gti6"]Got to love getting shiny bits. Looking good mate So True Chris ....thank you my friend...what’s your plans now ?...van etc ? Not too sure just yet, just want it sorted out 1st since someone has been f**king on with it since last time i had it You will get it sorted and in a twisted way ...you will enjoy it ATL inside without Alloy Box Day666 has attached the following image: |
Posted 9th Feb 2018 at 13:01
Post #1764
Cut a nice starting hole in the floor of the passenger side rear seat Bench Day666 has attached the following image: |
Posted 9th Feb 2018 at 17:42
Post #1765
All alloy Angle temp fitted / bolted and long flat head bolts used need to cut them off when fitting correctly...got to check it sits well ...Day666 has attached the following image: |
Posted 9th Feb 2018 at 17:44
Post #1766
I’m pleased with how it went ..needs trimming etc and removing alloy angle etc give it a clear lacquer coating It’s all level both ways with the wheels on the ground and needs to get bolted down after finishing.... It’s 1.5 inches higher underneath than the floor pan ....so that’s safe ....and well away from my Exhaust pipe but I’m still covering it with Zircotec layer Heat shield Day666 has attached the following image: |
Posted 9th Feb 2018 at 17:51
Cjwatson27
Post #1767
Looking good mate eat you was nervous cutting that hole in the floor ________________________________________ Old pugs don't die they just get faster |
Posted 9th Feb 2018 at 19:21
Post #1768
Perfect ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Posted 9th Feb 2018 at 19:25
Post #1769
quote: [quote="Cjwatson27"]Looking good mate eat you was nervous cutting that hole in the floor s**tting myself |
Posted 9th Feb 2018 at 20:21
Post #1770
quote: [quote="Day666"] quote: [quote="Cjwatson27"]Looking good mate eat you was nervous cutting that hole in the floor s**tting myself Hopefully Ross |
Posted 9th Feb 2018 at 20:22
Post #1771
Nah mate spot on ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Posted 9th Feb 2018 at 20:24
Post #1772
quote: [quote="superchargedblack1997gti6"]Nah mate spot on Thank you Ross means a lot from you Day666 has attached the following image: |
Posted 10th Feb 2018 at 12:16
Post #1773
Now I’ve sold my spare wheels =pro1.2 x16s ....I’m going back to good old heavy MO5s x 17s ..Hispec RX17S calipers with 360mm floating rotors are 3Weeks away Had to sell everything to buy this stuff ...the money trees bare nowadays Day666 has attached the following image: |
Posted 10th Feb 2018 at 12:23
marksorrento205
Seasoned Pro Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,223 Status: Offline |
Post #1774
This is the dogs todger!________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 10th Feb 2018 at 16:35
Post #1775
quote: [quote="marksorrento205"]This is the dogs todger! Thank you so much Mark ...it really is starting to get to where I wanted it ... But lots of Tears / sweat / long nights / lots of swearing / being skint loads on the way |
Posted 10th Feb 2018 at 18:14
