displaying posts 26 to 50 of 133
Pages (6): 1 [2] 3 .. last
Author Subject: 4 Pot Conversions
rich_w
Here's my Clio 197 / Megane 225 setup Cool
Contact Details:
07732 822546
Posted 5th Dec 2008 at 18:48
ash
Six Addict
BTCC AP 4 Pots 295x26 2 piece. (only pic I can find)
ash has attached the following image:
Posted 5th Dec 2008 at 22:42
ash
Six Addict
Compbrake Pro 7 Brembo and 330x32 2 piece
Posted 5th Dec 2008 at 22:43
ash
Six Addict
Compbrake Brembo fitted
Posted 5th Dec 2008 at 22:51
ash
Six Addict
Sean's V6 Brembo and Xantia Disc
Posted 5th Dec 2008 at 22:47
ash
Six Addict
Clio 197/ Meg 225 Brembo and 310x28 2 piece kit
Posted 5th Dec 2008 at 22:49
ash
Six Addict
Posted 5th Dec 2008 at 22:50
ash
Six Addict
Some weights I've recorded (per side):
GTI6 Caliper and pads 6kg IIRC (didn't write this one down!)
GTI6 Disc 5.9kg
Xantia V6 Disc ? (7kg guess)
406 V6 Disc ? (8kg guess)
BTCC AP Caliper and pads 3.1kg
BTCC AP 295mm Rotor and Bell 5.6kg
Renault Brembo, pads and adpater 3.7kg
310x28mm Rotor and Bell 6.6kg
406 Brembo and pads 3.7kg
330x28mm Rotor and Bell (7.5kg guess)
Compbrake Brembo, pads and adapter 5.4kg
330x32mm Rotor and Bell 8.5kg
Posted 5th Dec 2008 at 23:26
damien
wilwoods i had on the "shitter"
Posted 6th Dec 2008 at 13:45
Trigger
General Trig
Post #35
Don't forget mine Smile 4 pot Brembo's (radially mounted with special brackets) and 305mm 406 V6 ooupe discs. Fit under 16's with spacers just or 17's.
Posted 6th Dec 2008 at 17:43
Post #36
GTI6 Disc 5.9kg
Wilwood caliper 2.6kg and bracket 0.24kg
GSR caliper, pads and bracket 3.9kg
330x26mm wavy disc, bell and bolts, 3.2kg
How much do the pads weigh on the wilwood setup?
Posted 6th Dec 2008 at 17:59
Welly Forum Admin
Post #37
Not much.
The whole package, dry, with my early bracket
Vrs power!!
Posted 11th Dec 2008 at 05:26
Post #38
Hmm, that wilwood figure must be the total from the thread then Doh
Probably about 2.5kg inc. bracket and pads now then? Smile
Posted 11th Dec 2008 at 05:35
SteviePut
Post #39
So a saving of 3.5kgs per corner is a pretty good one then? How heavy are the spacers?
Posted 11th Dec 2008 at 12:57
Post #40
About ~240g, I'll double check on some better scales later.
Posted 11th Dec 2008 at 15:52
martinj
Post #41
1. Compbrake B4 4 Pots with 280x26 Rotors to fit 15" (CompBrake) - 2 piece discs
2. Willwood 4 Pots with 283x22 GTI6 Discs 15" (welly)
3. 406 V6 Brembo with GTI180 285x26 Discs 15" (ash)
4. 406 V6 Brembo with Xantia 288x28 Discs 15" (?)
5. AP BTCC 4 Pots with 295x26 Rotors 15" (VLR) - 2 piece discs
6. Fiat/Alfa Brembos with 305x28 406 V6 Discs 16" (tomtomtom)
7. AP 4 Pots with 305x28 406 V6 Discs 16" (rallyestyle)
8. Brembo GT 4 pot with 406 305mm disc 16"
9. Clio 197 Brembos with 305x28 406 V6 Discs 16"(rich_w)
10. Clio 197 Brembos with 310x28 Rotors 16" (ash) - 2 piece discs
11. 406 V6 Brembo with 310x28 Rotors 16" (ash) - 2 piece discs
12. Hi Spec Billet 4 calipers on 325mm, 2 piece discs. (lee gti6)
13. GSR Inv. 4-pots with 330x26mm scolloped rotors. (PhillipM) - 3 piece discs
14. 406 V6 Brembos with 330x28 Rotors 17" (ash) - 2 piece discs
15. Compbrake Pro7 Brembos with 330x32 Rotors 17" (ash) - 2 piece discs
16. 406 V6 Brembo's with (2 piece disc, red bells..) 330x28 rotor's 17" (aknight)
17. AP CP6600 4 pot calipers and two piece AP 330x28 discs - plenty of room inside 7x17 2120 speedlines (martinj)
6-pots:
1. KAD 6pots with 285x28 discs 15" (Binka & Gti6boy) - 1 piece
2.)Tarox 6-pots 310mm Belled discs, 17" TSW's (Steve_h gti6,) - 2 piece discs.
- Maxi rear axle hub spacers +53mm per side
- Maxi front steering rack extensions +40mm per side
Posted 11th Dec 2008 at 18:36
rallyestyle
Post #42
Nice setup there Martin, did you have to change the master cylinder at all?
Just Drive It
Posted 11th Dec 2008 at 20:14
martinj
Post #43
Hi,
No change to the master cylinder, the car still runs a servo but no abs. Once the tyres are up to temperature on an event the brakes are unbelievable, I needed to pull in lap belts on my harness as I was moving forward in the seat under braking.
Martin
Posted 12th Dec 2008 at 18:16
nicopug
Post #44
18. 806 V6 Brembo Magnesium calipers with 302*26 discs (nicopug)
6-pots:
807 V6 Brembos brakes : Bigger, lighter and quieter than thoose from 406 Cool
Nico from France, with a lot of Lions
Posted 13th Dec 2008 at 02:47
mabgti
NV motors
Post #45
Wow... i like themmm... whats the clearance like?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 13th Dec 2008 at 01:39
gti6girl
Post #46
They do look the buisness!
What discs are used and where do you get the brackets?
Posted 13th Dec 2008 at 01:43
nicopug
Post #47
Citroen sport shop LOL
Competition brake kit from the rallye car Citroen C2 Challenge Wink
[url]http://www.citroen.com/NR/rdonlyres/D40FC6FD-BAE8-4AC4-A571-2D1D3CD4AD37/44284/F11DisquesfreinAVFrontdiscbrakes.pdf[/url]
[url]http://www.citroen.com/NR/rdonlyres/D40FC6FD-BAE8-4AC4-A571-2D1D3CD4AD37/40578/F21EtriersAVFrontcalipers.pdf[/url]
Posted 13th Dec 2008 at 02:49
midlife
Post #48
Nice one NicoThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 13th Dec 2008 at 04:46
stu
Post #49
Clicky 1
Clicky 2
Posted 13th Dec 2008 at 04:52
rallyestyle
Post #50
They look really good Nico Yes How much did everything cost?
Are the calipers really magnesium? I know brembo use some expensive alloy mixes on their race calipers but for a road car they are a bit overkill as would cost a fortune Crazy
Just Drive It
Posted 15th Dec 2008 at 17:29
