displaying posts 1 to 25 of 149
Pages (6): [1] 2 3 .. last
Author Subject: Modified inlet manifold (Now fitted)
Going to have a go at getting more flow through my manifold so got started today by chopping the plenum chamber in half with a bandsaw! This exposed some rough, nasty looking trumpets just ripe for slicing off with my plasma cutterCool Will post pics when Chris come round and shows me how to do it again!LOL
Posted 26th Oct 2008 at 06:35
aperrott
has anyone done a before and after rolling road of this mod (done wellWhistle ?)
Posted 4th Oct 2008 at 00:11
Longmans may have, I was told that they were the first to try this mod. Dont know how true that is.
Posted 4th Oct 2008 at 08:03
Posted 4th Oct 2008 at 22:30
mechanical_repairs
I spy a snap on screw driver???
Carl
Posted 4th Oct 2008 at 22:38
midlife
Well done Dave, keep it upThumbs up
Perhaps this thread should be moved to projectsDunno
Cool
Team 330™Cool
Team "no front end or engine"
Posted 4th Oct 2008 at 22:49
Somebody knows their toolsWhistle
Posted 4th Oct 2008 at 23:29
gtisid
what happened to the other fella that cut his open and went to town on it? he sounded like he was going to do the whole thing with chopping the trumpets off and polishing it but he hasnt been on here for ages.
you can expect to see 18-20 hp out of this mod if done properly. i have a longmans one on mine and it is the best mod i have by far
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 4th Oct 2008 at 23:46
soton_s16
That much!? Unsure Blimey!Cool
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 5th Oct 2008 at 00:37
+18bhp just from that??
how are longmans doing it? cutting it and rewelding it or some other nifty method?
Posted 5th Oct 2008 at 00:41
SteviePut
One for one of you techys out there. . . If you were to extend the manifold and increase it's capacity, would it be beneficial?
Or how about a twin throttle arrangement? i.e one at each end? And then split it in two? So one throttle = 2 cylinders? A lot of work but i guess it could be done. Although the sensor side of things could prove tricky. Then there's the cost V's gain too I guessConfused LOL
Posted 5th Oct 2008 at 00:49
reminds me of bonos elise bodies on his maxi i believe, looks like a work of art
Posted 5th Oct 2008 at 00:52
crossflow
well unless you have a restrictor on the trottle body there isn't much point getting a larger volume plenum. Extending the inlet tracks could be beneficial for torque but not power so you would be gain more drivability more than power.
The two trottle set up won't work due to areodynamics in the plenum but if you were to joint the 4 inlets together with a small diameter pipes you are equalising the pressure between them and you might see a gain but it's all down to the wave lenghts in the plenum
Posted 5th Oct 2008 at 01:01
gtisid
longmans do cut it open, remove trumpets, and expand the chamber as the walls of my inlet feel very thin and then weld it back together. they also polish it inside and down the tube part (increasing their sizes port the throttle body too removing the d shape of the body to make a larger circle. i assume they change the gubbins in the throttle body aswell. it is supposed to work in conjunction with a custom made carbon airbox (not the bmc tat) only i couldnt get that to fit without extensive mods to rad, clutch,battery box and a couple of other things. still a good mod but can work out quite dear with longmans . 350 for the manifold and 180 for the throttle body if i remember rightly. i run mine with a 57i kit which has been the best of the 3-4 methods i have used
pugless
Posted 5th Oct 2008 at 03:21
chris with a pug
Carl
And he gets well upset when you hit them with a hammer
Posted 5th Oct 2008 at 04:58
A bigger airbos is normally a good thing, so long as you can work to keep the pulse tuning the same, hence the weird and wonderful shape airboxes on bikes these days - gets the capacity up, but keeps the pulse lenth front the runners low.
Caution, above post may not make sense, very p*ssed
Posted 5th Oct 2008 at 05:07
306andy
I'm in the process of finishing this off, just need it TIG welding back up Big grin
I cut the "trumpets" down to about a 5mm collar and have blocked off the resonator box
If any one wants pics...PM me
TEAM 205 GTi-5
TEAM Phase 1 GTi-6
xbox Live tag: SilverGTi6
Posted 5th Oct 2008 at 05:13
midlife
Get em posted up andyThumbs up
Cool
Team 330™Cool
Posted 5th Oct 2008 at 05:29
chris with a pug
What does the resonator box actually do? When he does this is it worth blocking the hole off
Posted 5th Oct 2008 at 17:14
puglover Banned!
the resonater box as far as i know helps to keep an even air distrubution to the cylinders and give it the engine note, no gains from taking it off so i wouldnt do it, and neither did longmans. This mod with throttle body though is well worth it transformed my car totally.
On a modded head and camed/remapped engine i have no doubt it is as good as throttle bodies.
Think you will sacrifice some low down torque though for a a rev happy engine with more top end. Pug designed that inlet for a reason. Yes
Changed mine over and sold it to GTISID and when i did my engine went to sleep Tired
Posted 5th Oct 2008 at 17:44
mechanical_repairs
Yeah post the pics up fella, i would like to see it, make sure you put some other tools in the shot tooLOL
Carl
Posted 5th Oct 2008 at 17:48
The larger throttle body that Longmans supply, is that a stand-alone mod or do you need a remap or other work to make it go. Just wondering if its a straight bolt-on job. (As those are the kind I likeLOL )
Posted 5th Oct 2008 at 20:29
SteviePut
But that's not to say it can't be improved tho. After all as good as it may be standard, it was still a compromiseYes
Posted 5th Oct 2008 at 20:37
collis
Stealing the thread here abit but does anyone local to southampton that i can buy a inlet manifold off because i got some spare time in my apprenticeship and want to have a play with it
"If you ain't first, you're last!"
306 1.4
mini city E
306 gti 6
205 gti 1.9
306 Rallye
Posted 5th Oct 2008 at 20:45
chris with a pug
When do you need it?
The one Jim cutting up is mine, so when he puts it on might be one avaliable.
Posted 5th Oct 2008 at 21:08
