about a quid's worth of resistors.
need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
Author | Subject: 205 gti 6 |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,824 Status: Offline |
Post #201
here's the one I made for an S16 conversion, same setup as required for the gti6about a quid's worth of resistors. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 30th Nov 2008 at 23:37
rikky
🦔 Location: cheshire Registered: 28 Feb 2004 Posts: 26,794 Status: Offline |
Post #202
clean your nails ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Posted 1st Dec 2008 at 01:56
taylorspug
Junior User Location: Haywards Heath, Sussex. Registered: 03 May 2008 Posts: 89 Status: Offline |
Post #203
smighall wrote: Mine did and i got that off the 205 site a couple of years ago. Mine seemed to work fine, but i'm not sure if it's the "proper" way of doing so to speak. It does work but be careful not to burn out the chip with the heat from the soldering iron. ________________________________________ 205 GTI6- Ledas, Tran-X diff, billet 4 pots, big bar rear beam, Jenveys and Emerald.Black P2 306 Gti6- Lowered, PTS rear spoiler- the daily hack! |
Posted 1st Dec 2008 at 04:12
captaink
Senior User Location: Exeter Registered: 18 Jul 2008 Posts: 579 Status: Offline |
Post #204
taylorspug wrote: smighall wrote: Mine did and i got that off the 205 site a couple of years ago. Mine seemed to work fine, but i'm not sure if it's the "proper" way of doing so to speak. It does work but be careful not to burn out the chip with the heat from the soldering iron. I'm guessing this is what you did to mine to get the rev counter working? I had no idea what to do with the cable thing I should you in my car. ________________________________________ When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.1993 L reg 205 with GTi6 engine and GTi6 brakes 1995 M reg FTO GPX manual |
Posted 1st Dec 2008 at 17:47
taylorspug
Post #205
Yeah its exactly what i did with yours. Im not up for titting about soldering in these loom things to every coil, when there is a far easier and neater solution!________________________________________ 205 GTI6- Ledas, Tran-X diff, billet 4 pots, big bar rear beam, Jenveys and Emerald.Black P2 306 Gti6- Lowered, PTS rear spoiler- the daily hack! |
Posted 1st Dec 2008 at 22:44
miles
Post #206
I'm sure the PCB on the rev counter converts a digital signal to a anolog signal for it to work, cut the resistor/diode out and you keep the digital signal, I know this works on Omex ECU 600 ECU's but not on the Motronic of the 8v Turbo's.________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
Posted 2nd Dec 2008 at 00:08
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
Post #207
All you need to do to get the tacho working is add a link wire on the pcb of the tacho like in the picture below (white wire is the link wire)Dont solder it directly to pin 1 of the chip or you run the risk of frying the chip. |
Posted 2nd Dec 2008 at 16:05
captaink
Post #208
taylorspug wrote: Yeah its exactly what i did with yours. Im not up for titting about soldering in these loom things to every coil, when there is a far easier and neater solution! Agreed. Easier is best and less wiring too. ________________________________________ When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.1993 L reg 205 with GTi6 engine and GTi6 brakes 1995 M reg FTO GPX manual |
Posted 2nd Dec 2008 at 17:51
super josh
Newbie Location: Watford Registered: 31 Jul 2005 Posts: 35 Status: Offline |
Post #209
pugjim wrote: All you need to do to get the tacho working is add a link wire on the pcb of the tacho like in the picture below (white wire is the link wire) Dont solder it directly to pin 1 of the chip or you run the risk of frying the chip. Also, If you solder the wire on the component side of the PCB, you don't need to remove the needle and risk f@cking up the tacho calibration. Josh |
Posted 2nd Dec 2008 at 20:14
mechanical_repairs
Post #210
Thanks lads you pair are the bo***cksCarl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Posted 2nd Dec 2008 at 21:17
mechanical_repairs
Post #211
A little more happened today, managed to extend the heater matrix pipes a little and got the cooling sytem to hold water (which was nice), ran it up for half an hour and everything looks fine, slowly starting to see the light at the end of the tunnel. Things to finish-Sort the speedo drive out, find the one that take a cable. (any clues as to what the part number is for the bit i need, think its a dt part) Solder in the wire for the rev gauge Fit the solid rear engine mount into the casing Fit the o/s drive shaft Build up the front. Fit the 306 battery box/ecu tray. A good half a days work if i could get the time to spend on it. Happy now all the lifters have filled with oil and its stopped tapping (always a slight worry in the back of your mind) Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Posted 6th Dec 2008 at 22:05
stue306
Scarface Pilot Location: Bet356.com Registered: 30 Mar 2003 Posts: 8,929 Status: Offline |
Post #212
looked good from what i saw of it today mate oh and thanks for sorting the vtr,im happy to have my car back but the boss is slighlty miffed to be back behind the wheel of the paxo and she was also dissapointed you didnt make her tea________________________________________ R.I.P pete,see you at the crossroadsso i dont forget [url =copyandpastelink]type a clicky title[/url] p2 gti-6, scooby wagon'restoration project' |
Posted 6th Dec 2008 at 23:15
mechanical_repairs
Post #213
stue306 wrote: looked good from what i saw of it today mate oh and thanks for sorting the vtr,im happy to have my car back but the boss is slighlty miffed to be back behind the wheel of the paxo and she was also dissapointed you didnt make her tea i have a kettle but never any milk, could have had a black one i suppose? Cheers, Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Posted 6th Dec 2008 at 23:58
stue306
Post #214
oh and thanks for looking at my dodgy electrics,did you see it having a spaz when i opened the door them two girls found it highly amusing just going to put up with it through the winter then have a look when it warms up a bit________________________________________ R.I.P pete,see you at the crossroadsso i dont forget [url =copyandpastelink]type a clicky title[/url] p2 gti-6, scooby wagon'restoration project' |
Posted 7th Dec 2008 at 00:11
bakes100
Regular Location: Colchester Registered: 15 Feb 2006 Posts: 172 Status: Offline |
Post #215
Carl , did my effort at a cooling system diagram come in handy?The part number for the dual speed sensor should be 6160 24. Its off the early 306's, s16 ect... ________________________________________ 205 GTi-6 = 179.2 Bhp @ 6650Rpm - SOLDSeat Leon Cupra R 225 |
Posted 9th Dec 2008 at 16:20
beez_neez_gt
Post #216
mechanical_repairs"]Well the day is getting close to the car being finished, had a really good session with it today and managed to get the engine in (yay)Lining it up to fit, it does look like it wont fit- A bit closer, to me to you- Lining it up to the engine and gearbox mount, had a little mishap with this when i decided to put the gearbox stud in the wrong hole in the gear box, it made the clutch arm hit the bottom of the battery tray, felt a bit of a tit when i realised what i had done. A bit further in, as you can see it is sitting happily on the mounts, just hope it clears in all the necessary places- Well as you can see the lump is in and guess what i am chuffed to bits as all the places people struggle with i seem to have been lucky, its close to the master cylinder but the exhaust and the front panel are fine (dont worry the master cylinder is going to be replaced, and sohas the fuel filter now)- Well up up up, car goes up on the ramp and i fit the subframe, i had to say finding all the bolts was a mission, i had forgot which ones were which, just got to fit my shiney new sump, yes i know but you could'nt leave it looking like it is now- Well thats about as far as i can go now, just fitted all the subframe and ancillaries, bolted all the driveshafts back in and put the wheels back on, it was great to see the car standing on its own feet again- Its a shane the inlet manifold is covered up by the front panel but ho hum, all thats left to do now is get it all wired up and connect the coolant hoses, managed to put all the fuel lines on and have just fitted the bonnet too. From the bay looking like this- To this- Hi Carl, Looks great, polo would be proud, LOL watch this space for when i start sorting my, 92 graphite grey,non sunroof out with the GTI 6 engine. At the mo the old engine is out and im slowly sorting out painting the bay out etc. Iv got the 309 rear beam sorted and refurb i just need to put it together and paint it me self. Iv also got 2 put my newish dash to put in as the original one looks more grey than the ph2 black. This 205 will be finished hopefully by summer next year, and will be totally MINT, the only thing it wont have for a while is a full respray. I also have a rare 86 ph1 205 GT im also slowly doing up, alot of rust but it a solid car as it passed another mot recently, buying it and stuff it needed has only cost me ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 9th Dec 2008 at 17:35
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,990 Status: Offline |
Post #217
Jesus Carl this is looking super smart Top work mate ________________________________________ Just Drive It |
Posted 9th Dec 2008 at 18:10
mechanical_repairs
Post #218
bakes100 wrote: Carl , did my effort at a cooling system diagram come in handy? The part number for the dual speed sensor should be 6160 24. Its off the early 306's, s16 ect... Yes mate you are a star, many thanks. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Posted 9th Dec 2008 at 18:58
Carl Chambers
Seasoned Pro Location: suffolk/norfolk Registered: 10 Sep 2004 Posts: 2,897 Status: Offline |
Post #219
mechanical_repairs wrote: bakes100 wrote: Carl , did my effort at a cooling system diagram come in handy? The part number for the dual speed sensor should be 6160 24. Its off the early 306's, s16 ect... Yes mate you are a star, many thanks. Carl Let me know what they quote you as last time I wanted one from Peugeot they wanted ________________________________________ Carl Chambersemail; pugnacious.peugeot@yahoo.co.uk . C.M.CHAMBERS CARS Peugeot Specialist Tel; 01379 586101 after 6.30 or 07889 082466 anytime. pugsport-racing.co.uk |
Posted 9th Dec 2008 at 19:32
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
Post #220
Looking great Carl, some nice attention to detail there |
beez_neez_gt
Post #221
Hi Carl,What kind of exhaust manifold you using ? Im thinking of cutting out the bulhead so i can use the original manifold, then reweld it up, for my conversion. Have you used the ph1 gear cable from the 205 ? Cheers George ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 9th Dec 2008 at 19:38
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Post #222
He used the gti6 one, but has cut it and re angled it to suit the 205 bulkhead.________________________________________ Dimma + Gt35 turbo =Solid rear beam mounts £130 07889376885 Dan |
Posted 10th Dec 2008 at 00:22
mechanical_repairs
Post #223
gkz 206 wrote: mechanical_repairs wrote: bakes100 wrote: Carl , did my effort at a cooling system diagram come in handy? The part number for the dual speed sensor should be 6160 24. Its off the early 306's, s16 ect... Yes mate you are a star, many thanks. Carl Let me know what they quote you as last time I wanted one from Peugeot they wanted ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Posted 10th Dec 2008 at 01:13
mechanical_repairs
Post #224
beez_neez_gt wrote: Hi Carl, What kind of exhaust manifold you using ? Im thinking of cutting out the bulhead so i can use the original manifold, then reweld it up, for my conversion. Have you used the ph1 gear cable from the 205 ? Cheers George A pic of it fitted to the lump, its angle is slightly tighter to the back of the block- Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Posted 10th Dec 2008 at 01:17
beez_neez_gt
Post #225
birk wrote: He used the gti6 one, but has cut it and re angled it to suit the 205 bulkhead. Ok thanks, how would i attatch the end i cut off to the wire so it will clip/attatch to the pedal and gearbox arm ? Cheers ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 10th Dec 2008 at 06:01
