displaying posts 26 to 50 of 659
Pages (27): 1 [2] 3 .. last
Author Subject: 2wd Offroad Buggy
Is the sound better or worse on this one:
Click
Only blipped to 5k there as the engine was warming though.
Or this one:
Clicky 2
Posted 28th Jul 2008 at 01:39
love the mudwings, supersingle or twin wheel width on the rear? Big grin
Posted 28th Jul 2008 at 03:55
Twins, 'cause there's some 8.5" wheels to go on the back shortly. LOL
It'll be a bit skittish at the back on those tyres when you change into 5th (at 120mph+ Ninja )
Posted 16th Nov 2009 at 15:43
fantastic project, fantastic thread and fantastic skill. well done m8 i am well and truly 100% jelous
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 6th Aug 2008 at 05:25
If someone would buy the bloody Fouquet I can get on with documenting the new car build LOL
Posted 6th Aug 2008 at 05:48
Right, got the louvers in the rear bonnet done, as well as a scoop for air feed to the radiators, just needs small naca duct over the engine inlet and the brakes fitting and we can race at last.
Should be running it at a small event at Newstead Abbey in 4 weeks, hopefully.
Posted 9th Sep 2008 at 21:22
pedro_de_la_cruz
all of this is so cool! Cool sometimes makes me wish id chosen engineering as a career path LOL
*R.I.P Pete Sims*
Posted 9th Sep 2008 at 22:04
New discs for it I've milled up from some CGI iron plate:
Ideally the rear needs to go vented now we have 260-odd bhp, but they'll do for now until we've got some pennies spare, as always it's gone over budget!
Posted 18th Sep 2008 at 18:47
rallyestyle
Whats a budget for if not to go over hey Wink
Bet you can't wait to get to that first event Yes
Just Drive It
Posted 18th Sep 2008 at 19:06
Post #35
yeah, but we've gone over it by about
Posted 18th Sep 2008 at 19:14
Post #36
Right, brakes are on, just needs my door finishing off and the front geometery resetting and we can actually go racing at last.
There's some other work to do like tidying up the rear bonnet and sorting an actuator system for on of the variable inlet systems -we're down about 20bhp at the top end as we've had to keep it closed currently Sad - plus the wider rear wheels to make, but nothing urgent, it's good enough to go for a spin anyway.
Big grin
At fooking last!
Posted 22nd Sep 2008 at 05:19
Post #37
Hmm, todays job seems to be see if you can find 2 problems for every one you fix.
Power steering weeping, fixed it, remembered bulkhead needed plating and that oil pipes hadn't been covered over yet.
Mesh the rear panels, realise air intake still needs ducting to protect it from mud and that passenger door still wants tidying up...
I'm going to have to get it an honorary Peugeot badge if it keeps this up.
Edit: If fact, there so many niggly bits to sort out, anyone free to lend a hand over the next couple of days before the weekend?
Coffee, bacon butties and passenger rides available, new undercrackers may be required.
Posted 30th Sep 2008 at 22:49
rallyestyle
Post #38
Sadly buddy im nowhere near otherwise i would jump at the cahnce to give you a hand Yes Looks uber crazy Devil
Just Drive It
Posted 1st Oct 2008 at 14:14
Post #39
Managed to crack on at a breakneck pace today actually, so should be OK for running it at the weekend.
I'm fooked though , been running on caffeine LOL
Posted 1st Oct 2008 at 23:34
Post #40
Pictures of it being used in anger on Monday Ninja Devil
Posted 4th Oct 2008 at 01:46
Post #41
Well, we managed to get there but unfortunately the exhaust got so hot it heated the engine bay enough to cause the fuel in the injector rail to boil, which means we need to extend the top scoop forwards and upwards into the airstream, and find some way to heat lag the exhaust (not as easy as wrapping it as the rotaries manifold temperature will melt wrap)
Posted 5th Oct 2008 at 04:56
Post #42
It went well though, although we got a bollocking for covering an official photographer from head to toe in mud, although if he will stand on the outside of a corner in damp woodland, that's his problem LOL
Posted 5th Oct 2008 at 05:34
Post #43
Right, air scoop has been extended forwards into the high pressure area right before the top of the windscreen - not pretty, but it works.
Unfortunately that doesn't give an room for the air to expand into to slow down and go around the curve into the radiator - so we've chopped down into the cab through the rear cross to make a huge airbox.
Few heatsheilds around the manifold and some lagging over the fuel rail.
Few niggles to sort out but hoping to be at Cadwell on the 25th Jan. to make sure she really will run cool LOL
Posted 22nd Dec 2008 at 04:03
Post #44
And I've got Ed bolting on some alloy replacements for various steel fixings and adaptors today, while I'm working on the miller, along with a lighter mounting for the brake discs, and some altered wheels.
By the end of the day she should have shed another 25 kilos Cool
Posted 23rd Dec 2008 at 15:48
Post #45
It's not the most elegant solution but:
Lots of missing paint lately where someone's been let loose with the grinder...
Posted 14th Jan 2009 at 02:00
Post #46
Well, warmed the doors up today to reform the bends needed now they've had time to relax, so they're finished at last, had to rebuild one of the fiddle brakes though after it popped a seal, luckily I'd got an old clutch cylinder from a Triumph with the same style seal in.
Bled the brakes, changed the fluids and filters, tightened the bolts up, loaded a new map on for a bit more top end power, and loaded it onto the trailer ready for Oulton Park in 4 hours.
Bwaarrrppp!
Posted 21st Feb 2009 at 06:51
Trigger
General Trig
Post #47
Bwaarrrppp!
Good luck !
Posted 21st Feb 2009 at 08:45
Post #48
I've grabbed the camera this time though LOL
Hopefully, if the rally track has enough grip with the mud tyres on, we'll get a chance to drop the tyre pressures and film a nice wheelie.
Posted 21st Feb 2009 at 10:59
Post #49
Right, had a few niggles but only small bits, great day out though.
Mud/terrain tyres will not turn in on polished tarmac though LOL
Posted 22nd Feb 2009 at 01:24
Post #50
Thanks to Ziploc on the talkphotography.co.uk site for that one.
Posted 22nd Feb 2009 at 06:21
