First trying to fix the rev counter: Checked/swapped the dials and they're fine, found the red wire (42something) in the loom by the airbox which is apparently signal from the ecu to the dials, read it with a multimeter and it reads 1v constant. Should it change with revs? Do I need to use the earth from the ecu too when checking?
The fuel pump doesn't seem to stop priming when you turn the key now either which may be related to the running probs...
Car's had new lambda/coolant/map plus has been pretty much completely rebuilt just 40k ago so think it's gotta be some electrical gremlins somewhere. Pretty desperate to have it going 100% for pugrun next week so any help or ideas would be much appreciated..
Plus can anyone tell me what the little black box behind the ECU does? could it be related to the fuel pump not priming properly?
Thanks...
Pics of my 6My 6 on Google Video thanks to coxy306Xsi
