Author Subject: FAQ - Cooling Fan system
gazzerdaman
Please do not post on this thread - thanks
Gary
Cherry Red GTi 6
Posted 4th Jul 2006 at 06:11
gazzerdaman
Cooling Fan FAQ from Peugeot Logic
— Introduction —
This page explains the basic principle of the various operating modes of the Peugeot 306 cooling fans.
The example we are using here is the two speed twin fans controled by a cooling fan ECU. Vehicle manufactured 1996 with A/C and 30 fuse box. Although the basic circuit remains the same in later models the fuse and wire numbers will be different.
— Overview of the system —
The engine cooling fan system is made up of the folowing parts. 2 fan motors, 3 relays, control unit and the coolant temperature thermistor (NTC).
The fans have 2 functions.
1. To provide engine cooling in slow or stationary traffic conditions.
2. To provide constant airflow for the condenser when the A/C is operating.
The 2 fan motors always run together and have 2 speeds available. At low speed the motors' power circuit is switched in series and at high speed the circuit is changed over to parallel. A ballast resistor is therefore not required. The switching of the power circuit is done by the 3 relays which, are controlled by the control unit.
The following tasks can be performed by the control unit: Switching of the fan relays, illuminating the "STOP" warning light, illuminate the warning light on the temperature gauge, prevent the A/C compressor from operating under extreme engine temperature or under full engine load, timed post cooling when engine is shut down with the fans operating.
In order to carry out these tasks it receives inputs from the coolant temperature sensor, the air conditioning control panel, the refrigerant pressostat and the engine ECU.
Gary
Cherry Red GTi 6
Posted 4th Jul 2006 at 06:18
gazzerdaman
— Fan and relay layout —
Use this graphic to identify and relate the components to the diagrams.
gazzerdaman has attached the following image:
Gary
Cherry Red GTi 6
Posted 4th Jul 2006 at 06:16
gazzerdaman
— Location Of Components —
Control Unit - also known as Bitron unit
The cooling fan control unit is located under the left guard below the head light. Remove the inner guard cover to gain access.
Temperature Sensor
The temperature sensor us mounted on the heather tank on the cylinder head at the bell housing end. The sensor is brown with a brown 2 way connector.
Fuses (power)
Fuse 33 and 34 in the fuse box near the battery.
Fuses (relay coils)
Fuse box with 30 fuses in passengers compartment.
Fuse 7, battery + to left fan relay and control unit.
Fuse 3, ignition + to right fan relay and change over relay.
Fuse 2, ignition + to control unit.
Earth connection 1
On the left chassis rail in front and below the battery carrier.
A/C Control Unit
Integrated in the control panel on the dash board.
Gary
Cherry Red GTi 6
Posted 24th Aug 2006 at 23:22
gazzerdaman
Wiring Diagram
Gary
Cherry Red GTi 6
Posted 4th Jul 2006 at 06:27
gazzerdaman
— Low Speed Operation —
Condition for low speed call
The low fan speed is called for:
1. When the engine temperature reaches 97°C and it will turn off when the temperature has droped to 90°C.
2. When the air contitioning system is switched on. It will run permanently regardless of engine temperature.
Power circuit explained
Only the "left fan relay" is energised. This relay has a permanent battery + supply from fuse 7 (fuse 10 for a 13 fusebox) in the passenger compartment fusebox.
When the coolant temperature reaches the threshold (about 97°) the control unit provides an earth for the relay coil and the contacts are now closed. This completes the power circuit for both fans.
The power circuit starts at the battery, to the engine bay fuse box through fuse 33, to pin 3 at the "left fan relay", out at pin 5 of the relay to the left fan motor, from here to the "change over relay".
The change over relay is at rest and provides a path between pin 3 and 4 to the right fan motor, the circuit is complete at pin 2 of the right fan motor when returning to earth.
The fans are switched in series and run at ½speed. The voltage drop between the 2 fans is indicated in the diagram below with a lighter collour trace.
In the low speed configuration we have one circuit for both fans. The motors operate in series.
Gary
Cherry Red GTi 6
gazzerdaman
Low speed Diagram
Gary
Cherry Red GTi 6
gazzerdaman
— High Speed Operation —
Condition for high speed call
The high fan speed is called for:
1. When the engine temperature reaches 107°C.
2. When the A/C refrigerant high pressure threshold is reached.
3. When the temperature sensor circuit goes faulty. (open circuit)
All 3 relays are now energised.
See the low fan speed operation above for the "left fan relay" control.
The "change over relay" and the "right fan relay" are provided with ignition 12V via fuse 3 from the fuse box in the passenger compartment. (fuse 7 for a 13 fuse box).
When the coolant temperature reached the threshold, (about 107°C) the control unit switched the "change over relay" and the "right fan relay" to earth.
Left fan circuit, red trace.
The left fan motor is supplied with current from the battery via fuse 33 and the "left fan relay" (same as in low speed operation), from the motor the path leads to the "change over relay". This relay is now energised and directs the current to earth.
Right fan circuit, blue trace.
The right fan motor is supplied with current from the battery via fuse 34 and the "right fan relay". From the motor the current returns to earth; this completes the circuit.
In the high speed configuration we have a separate circuit for each fan. The motors operate in parallel.
Gary
Cherry Red GTi 6
Posted 4th Jul 2006 at 06:17
gazzerdaman
High speed diagram
Gary
Cherry Red GTi 6
Posted 4th Jul 2006 at 06:28
gazzerdaman
Thanks to Cosmic Spanner for finding this.
Material obtained from Peugeot Logic Website
Gary
Cherry Red GTi 6
This thread has been locked
