Author Subject: Replacing inlet manifold gasket
captainash Admin
Undo clip (A)
Unplug breather hoses (B ) to reveal hidden manifold bolt (I)
Disconnect throttle cable (C )
Disconnect plug (D)
Remove bolts (E) and (F)
Unplug vacuum hose (G)
Loosen hidden bolt (J) with a spanner and remove with fingers
captainash has attached the following image:
quote:
Ash is in charge, from afar
Posted 31st Jan 2006 at 16:15
captainash Admin
Jack car up and remove bolt K from underneath
Posted 30th Jan 2006 at 09:44
captainash Admin
Remove all hex bolts and 13mm nuts holding the manifold to the head. If you don't have a deep enough 13mm socket, pull the fuel rail out slightly and use a spanner
Lift the front end of the manifold over the bracket from bolt (J) and pull out to reveal the old gasket
BEING VERY CAREFUL NOT TO DROP ANYTHING INTO THE CYLINDERS, remove the old gasket
Posted 24th Jan 2006 at 11:03
captainash Admin
Fit the PTFE gasket in place
Refit the manifold, ensuring it makes a good fit over the gasket
Replace all nuts & bolts
Reconnect hoses and plugs
Posted 24th Jan 2006 at 11:04
This thread has been locked
