displaying posts 101 to 125 of 147
Pages (6): first .. 4 [5] 6
Author Subject: Mike Blands Race Car
matty_rallye
Post #101
That shifter setup really is lovely! Shame they are so dear Sad
2.1 16v 306 Rallye.
Posted 12th Sep 2020 at 21:14
blandy
Post #102
Yep there a lot of money (luckily I didn’t pay anywhere near that though)
Hope it’s as good as it’s made out to be 🤞
Posted 12th Sep 2020 at 21:30
Post #103
Looks fantastic Mike keep the updates coming on the setting up and install ...I don’t know of anybody personally in this country that’s run one ? ... good luck m8 Thumbs up
Posted 13th Sep 2020 at 03:25
blandy
Post #104
Only ever seen one In person which was in John whelans animal of a 306 which did a few races in tricolore A few years ago
https://youtu.be/k4GWqyqQL54
Posted 13th Sep 2020 at 09:09
Post #105
Fantastic Vid and it looks great and very direct and precise....is he still about to speak to and ask advice ?
Posted 13th Sep 2020 at 19:35
blandy
Post #106
yeah id already spoken to him before i got it
Posted 14th Sep 2020 at 12:36
blandy
Post #107
Few little updates, diffs back after having service and new plates fitted. Went to refit but found the crownwheel bolt threads had seen better days so put a stop to that plan. With no diff to fit I carried on with the installation of the gear lever. Again like the satchshift a bit of a pain to fit especially adding yet more holes in To fit the cables through, so got some tidying up to do on the tunnel now to fill up the old satchshift hole.
Levers in and after a lot of tweaking feels very good and super precise. Sure will need some more tweaking once running etc but will mark up cables etc before pulling back out and welding up the tunnel
Posted 20th Sep 2020 at 19:33
Post #108
Fantastic Update Mike ...
Yep always change the Bolts ...
I found they strip if you don’t loosen them each gradually ....
Welshpug told me years ago he’s never had a issue as long as you do that but I still stripped a couple Thumbs down
Posted 21st Sep 2020 at 19:30
matty_rallye
Post #109
Nice one. Does this mean you have a satchshift to sell?
2.1 16v 306 Rallye.
Posted 21st Sep 2020 at 19:53
blandy
Post #110
Sorry satchshifts long gone after having manifold clearance issues been running a rebushed standard set up this year
Posted 21st Sep 2020 at 21:09
blandy
Post #111
Been ok before but not this time, defiantly not worth the risk
Posted 21st Sep 2020 at 21:11
eiei0
Post #112
Wow haven't seen that car in years, it was mental quick, serious donkey in it, used to run rings around everything over here when it came out to play,
Posted 22nd Sep 2020 at 01:41
blandy
Post #113
Yeah I only saw it a couple of times but was certainly rapid
Cae all now in and adjusted not in a position to run and move the car yet but feels good static at least
Posted 26th Sep 2020 at 20:39
blandy
Post #114
Also relocated the air intake for the airbox. Noticed after a few races with the air feed comming from the fog light hole with a 4” tube it’s been rubbing on the gearbox so not only spli the hose a little, is also getting pretty hot during a 20min race so not ideal.
So now much shorter and more direct, took some careful cutting of the grill but clears the bonnet and still in direct air
Posted 26th Sep 2020 at 20:45
Post #115
Fantastic update Mike
Keep um coming m8 Thumbs up
Posted 27th Sep 2020 at 01:07
blandy
Post #116
Stripped down the suspension ready for the next big addition - decided to concentrate on improving the suspension and generally how it drives rather than more power at this stage. Ordered a new top mount bearing as worn and stripped and cleaned the Coilovers along with some different springs ready for this when it’s made
Posted 7th Oct 2020 at 21:10
Post #117
Bloody fantastic upgrade Mike Thumbs up
Great update
Posted 20th Oct 2020 at 18:27
blandy
Post #118
Not many images to share but a bit going in with a few changes along the way. Started to fit the new lower suspension arms as pictured above, stripped cleaned and changed the springs on my bc coilovers which allthough all good and having served me well have decided to now to change to complete the front suspension upgrades with some new coilovers.
But as with everything the new coilovers will also require some modifying this time to the strut tops as they will use different top mounts which require plates to be welded in which in itself isn’t a drama... allthough I already have strengthening plates fitted so they’ve felt to come out so I can replace with the new when they arrive .. so out with the grinder
Also the kit comes with roll Center correction which includes some weld on track rod ends with rose joints. This highlighted that my original tie rods where a little on the “used” side so new tie rods fitted, and ends welded on
Brakes are also being adapted to fit the new hubs with the new hubs having different offset so will likely be new bells and rotors commissioned by satchell. So hopefully by end of it will have one pretty planted gti
Posted 12th Nov 2020 at 20:33
Post #119
Fantastic update Mike ...totally worth it mucker Thumbs up
Keep the updates coming on this unique race car you have redesigned x
Posted 13th Nov 2020 at 12:37
RallyeRed
Post #120
Mike, does the subframe supplied have a ‘squashed’ depth like the maxi rally cars? I’m guessing not given the roll centre adaptors on the upright but thought I’d ask..
Posted 19th Nov 2020 at 09:43
blandy
Post #121
To my knowledge the frame is a modified standard unit, that is strengthened and adapted to fit the rose joints on the new arms etc
Posted 19th Nov 2020 at 13:33
ben306
Post #122
Just had a read through this and love it. Great to see all the hard work is giving plenty of smiles!
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 19th Nov 2020 at 17:19
blandy
Post #123
Thank you. It’s definitely been built to be used and abused 😀
hopefully the new additions will translate to improved lap times etc. This year was all about learning the car and learning some race craft, now just trying to perfect on what’s there already and make it further up the grid.
Posted 19th Nov 2020 at 20:45
ben306
Post #124
Ill just be happy to get mine back on the road and on some trackdays again
3 sisters circuit
Few laps at Blyton
Posted 20th Nov 2020 at 12:58
Post #125
Hi Mike
Hope your well
Yes your 100% correct standard subframe that’s been welded and had strengthened supports fitted plus rose joint adaptor plates and no ARB as you know Thumbs up
Posted 21st Nov 2020 at 15:36
