displaying posts 51 to 75 of 88
Pages (4): first .. 2 [3] 4
Author Subject: Stef's Supercharged 205 GTi6
Post #51
Looking lovely there Stef! Cool
Posted 14th Sep 2016 at 22:36
stef306
Post #52
Finally got around to fitting the new clutch. Got the box out within 15mins (sad i know) Pulled the oem clutch off showed clear signed of heat and was extremely glazed. Decided to inspect the flywheel for any issues, Apon inspection we found lots of stress cracks and lots of high spots. I wasnt happy about putting it back so got on and sorted another. Big thanks to rich!, really didnt want to buy a s/h unit as ive see loads with high spots along with heat marks from oem clutches. Also fitted some new flywheel bolts from peugeot. Nice touch from ttv is the pressure bolts have now been upped to a decent bolt size m8 instead of peugeots stupid m7!
Flywheel has made a real noticeable difference, Omex has delt with the change well and idle is as smooth as it was before. Clutch is nice and wouldnt know it was a paddle but bites alot harder, worthy upgrade!
Stef Smile
1990 205 gti6 supercharged
Posted 5th Oct 2016 at 20:46
rich_w
Post #53
Looking good Stef Smile
Contact Details:
07732 822546
Posted 6th Oct 2016 at 08:07
Post #54
The vxr injectors make much of a difference then? Wondering if they would be a straight swap on mine or would need a completely fresh map.... I know it wouldn't be perfect without mapping obviously...
Posted 6th Oct 2016 at 09:28
stef306
Post #55
yes huge difference imo. My map is much tidier and smoother, the spray pattern is a huge improvement im now using 3/4 of the duty i was on the old injectors
Posted 6th Oct 2016 at 21:02
blandy
Post #56
What clutch are you using?
Defiantly need to get me one of those flywheels. Only reason I didn't get one last week when I had my box off was in case the omex on mine needed any tweaking. Will get one over the winter though
Posted 7th Oct 2016 at 18:48
Post #57
I've just told a guy to ask you about a recon 205 1.9gti rear beam Stef. He should message you on Facebook shortly.
Posted 7th Oct 2016 at 19:04
stef306
Post #58
I had it made, told them what i wanted and they made it.
Posted 12th Oct 2016 at 20:19
stef306
Post #59
Thanks! hes been in contact
Posted 12th Oct 2016 at 20:20
stef306
Post #60
New suspension has turned up :Big Grin
Direct from bilstein 205 grp a bodies with inverted mono tubes with Eibach springs. Big thanks to miles for sorting them for me.
will be sorting top mounts soon.
Stef Smile
Posted 31st Oct 2016 at 20:29
blandy
Post #61
Very nice
What are you running on the rear
Posted 31st Oct 2016 at 21:36
stef306
Post #62
309 tube, zero toe arms, -1.5 deg camber, 22mm tb's 25mm arb and soon will have the bilstein grp a rears to match the front.
Posted 1st Nov 2016 at 19:16
Post #63
Looking Great Stef ...keep the updates coming please Thumbs up
Posted 1st Nov 2016 at 19:39
stef306
Post #64
Ill try buddy Smile
Had a few minutes at work so fitted the new mintex 1144 pads and brembo discs with new fluid. Can already feel the difference only time will tell.
Stef Smile
Posted 2nd Nov 2016 at 18:01
stef306
Post #65
been hearing a knock on right hand lock almost a cv knock. Got it on the ramp to inspect during the week. Gave the suspension a good wiggle nothing jumped out at me. Removed the front wheels to find the bracket to my rosejointed droplinks had sheared haha.
Fixed it for now with electric magic.
Ill redesign them at some point but for now it works.
Stef Smile
Posted 6th Nov 2016 at 17:41
Post #66
Would it be worth strengthening them with some triangulation either side? Might make it a bit more awkward getting a spanner or socket on the bolt but it would help prevent them breaking again so easily. You could even weld in the triangulation so it makes the hexagon captive, ruling out the need for a spanner/socket on that side of the bolt.
Posted 6th Nov 2016 at 20:29
clen666
Post #67
Looks like there is a dab of weld on the bolt anyway
Team 'unintentional rat look'
Posted 6th Nov 2016 at 20:45
stef306
Post #68
Yeah ill do something with them at somepoint, I have welded the bolts to the brackets already but a better bracket design will be better.
Posted 6th Nov 2016 at 21:59
stef306
Post #69
Nothing to report on this lately other than reliability.
Cleaned the floor up abit hasnt been touched in 6 years.
Mot time
Passed with no advisories another ticket with 13months.
Went to a show last weekend dont normally do shows other than pugfest but it was local so i went.
Met a really cool dude
Manged to come away best "stripped" the car not me my clothes stayed on i promise! LOL:
meanwhile its current state
Stef Smile
Posted 28th May 2017 at 20:46
stef306
Post #70
Had been nursing the engine for a while, started pushing water out and started to run hotter. Decided it was time to pull it out.
The original plan was just to lift the head and repair what was needed.
Untitled by stefan golesworthy, on Flickr
Which in turn changed to this.
Now it had become a full engine build and a engine bay tidy and repaint.   :itwasntme:
Engine strip began
Yes a FIBRE gasket! I did 40k on this 35k with boost!
Head and valves seemed ok.
The head was then sent to sandy to work his magic Smile
in the mean time the block was fully stripped and inspected, Big ends where in top shape but the mains had taken a small blow.
It really wasnt worth spending money on a cast crank so i raided the spare hdi engine for its forged crank Big grin
quick test fit of the 88mm crank
xu5/7/9 thurst washers need to use this crank in a xu10 block.
block was cleaned and gave it a slight hone. The block wasnt scored or did it have any lip at the top it was mearly to score bore up.
genuine peugeot mains fitted to the block
Pistons in and mated to the crank with some arp bolts.
Head returned from sandy
About as much as i can show you Razz
The head also received new valve guides, and serdi valve seats head was skimmed abit more than expected but wont effect the build.
head was put back on with a genuine gasket, genuine bolts and added some newman camshafts to the mix.
secretly there just boxes Wink
The standard exhaust manifold was modified, the flange appeared to be the restricting part as it really funnel necks down. I removed the flange and opened the collector to match the exhaust sizing i plan to use.
The mandatory v-band was added
Wont stay that clean im sure.
I turned my attention to the engine bay.
I fully stripped all the paint off the bay with industrial paint stripper as it was easier. Then my good friend that paints at mclaren came down and painted the bay for me. Not bad considering the conditions.
fuel lines were replaced to ali lines and clipped to the bulkhead.
engine was lifted back in, surprisingly i didnt scratch anything LOL:
Oil cooler was moved to sit behind the fog light hole in the valance.
started the exhaust build
The engine started for the first time, Ecu naturally isnt happy. Ill be getting it back down to sandy at some point.
The day before mapping, I drained the oil from the engine as it was only used to run the engine for the first time and to get it through its first lot of heat cycles.
Drain and refilled with mobil 10w/60 and a genuine oil filter.
Oil choices can be very opinionated but ive used this stuff since owning the car and its served me well with no failures or issues so i just continue to use it.
Loaded up and headed for Cornwall!
Arrived at ARM bmw and motorsport and what a place!
As always nothing goes to plan and tbh i never expected it to with a new setup. As we got into the higher pulls and higher loads suddenly we had a real rough idling issue, after about 30mins of looking for a air leak we discovered the exhaust cam pulley had slipped! luckily i had built the engine with plenty of valve to piston clearance so a case of moving the cam back and all was good again! With that said it happened about 3 times again only after full hard pulls.
I then moved the belt and the pulley to the end of its adjustment so it couldnt move even if it tried which worked! Sandy then continued to work his magic which then saw us welcoming the 205 into the 300hp club! something id never expected to see! completely shocked.
We called it a day with the map pretty much there i was told there was more in it but for now its enough lol. The car had been completely transformed and is very drive-able and a animal when needed.
Sadly the gopro failed and the only video i have was filmed on a android potato!
Stef Smile
Posted 15th Dec 2017 at 22:59
Post #71
Nice update.
Care to share your new CR?
I guess it's hard to say from all the other work you've had done but what do you reckon to the new camshafts? (I'm guessing you went for some specifically for s/c?) How much boost is it running now? Smile
You've literally done most of what i had planned for my car over the next couple of years, always a few steps ahead of me! Razz LOL
Posted 16th Dec 2017 at 00:49
stef306
Post #72
Its around 10.5-10.8:1 its hard to say the head was skimmed past the normal point. Im now running less boost about .6bar mainly due to the increased cc i guess pulley setup is still the same and the least boost it will run.
Posted 16th Dec 2017 at 09:58
Post #73
Impressive result then Thumbs up
Posted 16th Dec 2017 at 11:09
Post #74
Brilliant Updates Stef Thumbs up
Keep them coming
Posted 16th Dec 2017 at 19:00
99rallye
Post #75
I love this car. A real credit to you Stef
Posted 16th Dec 2017 at 22:44
