check the connection on the alternator and the wire link back to the battery via the starter + tag
displaying posts 26 to 38 of 38
Pages (2): 1 [2]
Author | Subject: S/C 306 only getting power at one coil? |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
where is the 12v feed for the engine loom coming from the alternator like on the std 6 loom?check the connection on the alternator and the wire link back to the battery via the starter + tag |
Posted 14th Mar 2016 at 14:20
Seasoned Pro Location: Bristol Registered: 20 Apr 2013 Posts: 5,212 Status: Offline |
Good Luck Ash ....I had 4 days of hell with dash Electrical problems ....found out what it was by accident as I nearly gave up m8 ...You may of seen it was my Main fuse box inside the car corroded inside & it appears now that having welding done on my car made finished it off Like yours it was working one day after the welding & then nothing for no reason ...was no reason at the time for it ? Keep us updated Ash |
Posted 14th Mar 2016 at 19:50
cully wrote: where is the 12v feed for the engine loom coming from the alternator like on the std 6 loom? check the connection on the alternator and the wire link back to the battery via the starter + tag I do remember the previous owner unable to start the car after fitting the new engine then saying he had done the alternator connections wrong.... Maybe he didn't sort it properly and it's now cocked something up. However the car should still run without the alternator connected just won't charge. And if the wire wasn't connected or excessively corroded at the battery end then the starter wouldn't turn the engine over. ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 15th Mar 2016 at 08:09
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,817 Status: Offline |
armzs16 wrote: However the car should still run without the alternator connected just won't charge. nope, if alternator is not connected the double relay gets no power. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 15th Mar 2016 at 08:15
cully
without the ring tab on the alternator + to the battery the car will just turn over and nothing will fire on the engine loom,but you may see a back feed from other circuits from off the car loom into the engine loom giving you a low voltage of 9v |
Posted 15th Mar 2016 at 09:18
welshpug! wrote: armzs16 wrote: However the car should still run without the alternator connected just won't charge. nope, if alternator is not connected the double relay gets no power. Care to explain? As the loom only goes from there to the battery. Would still be battery voltage feed to the relay which should be enough to make a spark.... but what cully is describing sounds just like the problem they are having.... Mind you depends which ring terminal you are talking about as there's 2 that come off the 13mm and one on the 8mm IIRC. I was just meaning the main start charge loom but presumably you guys are talking about one of the other 2? ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 15th Mar 2016 at 10:23
Any progress on this? ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 24th Mar 2016 at 08:03
rallyeash
Fixed________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Posted 11th Apr 2016 at 15:35
Post #35
what was it? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 11th Apr 2016 at 15:44
rallyeash
Post #36
Previous owner bodges coming to light yet again!!. We noticed a while ago that the locating clips on the harness connector block were broken going onto the ecu.we were working on the car saturday doing other bits and tried to start it on the off chance, it fired up on three cylinders, so we were poking bits, wiggling things etc and pete put some pressure on the ecu connection and we had firing on all four cylinders... Not sure the long term fix as the connection is part of the main harness.. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Posted 11th Apr 2016 at 15:57
Post #37
ah! easy fix tbh, buy or source a new/replacement connector and swap the pins overthe 55 pin 3 row bosch plug is very very common. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 11th Apr 2016 at 16:26
Post #38
Knew it would be a dodgy connection somewhere glad you got to the bottom of it. People tinkering themselves or "having a go" often leads to more harm than good....________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 12th Apr 2016 at 20:09
Pages (2): 1 [2]
