displaying posts 1 to 25 of 88
Pages (4): [1] 2 3 .. last
Author Subject: 309 Type R
rallyeash
Hi all, thought I'd share my new project. A K20 engined 3dr 309 in fast road spec.
I purchased a 47k 1 owner 1.3 style 2 weeks ago.
Collected from Essex
In the workshop. H ERO number plate!
Short time later
Beast of an interior. Although very tidy!
Lowered the beam
60k (genuine) engine purchased from a 2005 CTR premium.
Getting it ready
Running gear removed
Engine arrived today
Engine stripped down to what I want to work with. Some bits will be re fitted. Ie water pump.
Slid under
Took about 2 hours this evening getting the height, angle etc correct
Took a section out of the inner wing for the gearbox mount.
Updates to follow.
309 3dr K20 Type R
Posted 17th Dec 2014 at 22:12
Ok I have to ask - why ? Aren't those engine all multiplex ?
Posted 17th Dec 2014 at 22:31
Heroic.
Aftermarket management.
  • Posted 17th Dec 2014 at 22:32
    RetroPug
    Like it, got a soft spot for 309s.
    Posted 17th Dec 2014 at 22:40
    rallyeash
    Bodies and DTA my friend.
    Why not, I'll have a road going pug which will be a blast. 225hp ish, Vtec and 800kg.
    309 3dr K20 Type R
    Posted 17th Dec 2014 at 22:53
    MisterGTR
    Liking this lots.
    When I see stuff like this, I wish I'd paid more attention to my dad!
    Posted 18th Dec 2014 at 00:43
    pug_306
    Looking good buddy, Does Sandy still have his 309 V Tec Ash ?
    1992 205 GTi6
    205 Turbo 340bhp
    Posted 18th Dec 2014 at 08:42
    rallyeash
    No that was broken around 5 years ago I think. Shame as it was a beast.
    309 3dr K20 Type R
    Posted 18th Dec 2014 at 08:55
    rallyeash
    This morning, got into work and had a rummage for some bushes and dad came up with some Landrover defender suspension bushes...
    Going to use two in parallel for the gearbox mount.
    Required a small trim down so they would fit width wise and so the inners will butt up together.
    Trimmed, left one sat the other way round to show before and after.
    As they will sit
    Plenty of space here still. I will get some pipe that can be welded to the chassis and these bushes will get pressed into them.
    309 3dr K20 Type R
    Posted 18th Dec 2014 at 09:42
    pugheaven
    This is going to be epic Thumbs up
    Just a shame it's a jap engine, would be so much better with a French engine like a 2l turbo from the megane Devil but I can imagine that would be a lot more work
    Posted 18th Dec 2014 at 11:12
    rallyeash
    I'm a N/A engine man to be honest. This engine is arguably one of the best 4 cylinder production engines ever built and it should make a lovely drivable fast road old school pug.
    Even though it'll be a budget build it's not a cheap build. I'm hoping to complete it for around 5k. So far it owes me £2,000. The expensive bit next is the DTA S60, loom and bodies. But that'll be in the new year
    309 3dr K20 Type R
    Posted 18th Dec 2014 at 11:44
    pugheaven
    No doubt it will be an awesome car bud, those k20 lumps can make some very good power n/a unlike any psa engine
    Posted 18th Dec 2014 at 12:35
    rallyeash
    That's the trouble, my gti6 engine In the Rallye cost about the same as this whole car build! Same power too!
    309 3dr K20 Type R
    Posted 18th Dec 2014 at 12:48
    gwyn rallye
    Awesome. Looking forward to seeing how this develops. Those engines sound superb as standard, will sound epic on bodies Im sure. Liking the 309 number plate too!
    Bianca white 306 Rallye
    Arctic blue Clio 182 FF
    Alpine white 205 1.9 GTI
    Posted 18th Dec 2014 at 16:13
    fatlapit
    my mate has a ep3 type r not on bodies makes 265 bhp. it has tdi north cams. piggy back ecu. skunk2 inlet and tb. group m intake. sum crazy manifold and a 3" exhaust. its getting jackson cgarged soon.
    tbh you cant beat a honda for bang for ya buck.
    Posted 18th Dec 2014 at 20:10
    rallyeash
    Front lower engine mount now done.
    Used some 25 x 3 angle to strengthen the front end, welded the corners into the chassis legs and stitched it across the lower slam panel, ran a bead of panel sealent across the edges to stop and water getting inside and rusting inside out wards and stuck some pink oxide over it all
    Cut around the chassis leg to add strength
    Trial fitment with engine in.
    Engine removed, paint ground back, welded, sealed and painted in oxide
    309 3dr K20 Type R
    Posted 19th Dec 2014 at 10:29
    rallyeash
    Offside engine mount cut out
    On the near side added 25mm angle on the leg and backed upto 25mm angle on the wing. Massive amount of strength added here now. I hate welding to thin body work, prefer 3mm and above.
    Still a fair amount before it's finished here but it's a start. Engine back in next to tac in the mounts...
    309 3dr K20 Type R
    Posted 20th Dec 2014 at 14:23
    orta
    Love 309s! This one is mental and very unique. You be at any of the shows next year would love to have a peek ?
    CLUB BLACK RALLYE
    ||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
    Posted 20th Dec 2014 at 20:57
    rallyeash
    Yeah most of them, although the 205 gets first pic... If someone else drives it'll be there.
    309 3dr K20 Type R
    Posted 21st Dec 2014 at 08:59
    Looks awesome this
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 21st Dec 2014 at 18:01
    I'll take the 309 for ya bud or the 205 ?
    Posted 21st Dec 2014 at 18:31
    rallyeash
    More progress today...
    Cut out the lip on the engine mount which revealed a flimsy section!
    Added strength with an angle section. I also added one on the backside on the wing, didn't take a pic of that though.
    Mounts added
    I've changed my mind on the gearbox mount, I've decided to use one larger mount, I used the original civic mount to mock up what I'm after. This isn't what I will be using, I will be something similar but on a smaller scale. A fairly simple setup.
    309 3dr K20 Type R
    Posted 21st Dec 2014 at 21:10
    For a second there I thought it was a huge P bush LOL
  • Posted 21st Dec 2014 at 21:27
    fatlapit
    could you not graft a subframe into the chasis of a 309?
    Posted 21st Dec 2014 at 21:43
    rallyeash
    It will be similar In shape. I just knocked that up to work out the design of what I want. It looks ugly but it's got my head around what I need to do here.
    309 3dr K20 Type R
    Posted 21st Dec 2014 at 22:03
