Innes drummond
Author | Subject: Fitting original air box help !!! |
![]() Regular ![]() Location: alloa Registered: 10 Jan 2013 Posts: 157 Status: Offline |
Recently got another 6 and was wanting to put the original air box on from my old pug noticed it had a k and n cone filter fitted to the gearbox so managed to remove it but when I tried to fit the original air box I couldn't find where to attach it I seen on the forum someone mentioned a triangular mount near where the engine loom meets the car loom but I didn't have much luck so for now just gona put the kand n back on after a good clean if anybody could help me or has a photo of what I should be looking for id really appreciate it cheers ________________________________________ Innes drummond |
![]() Seasoned Pro ![]() Location: DoncastAAAAARGH Registered: 13 Jan 2008 Posts: 4,640 Status: Offline |
An old picture i found, may be useful for you? ![]() ![]() ________________________________________ Goldie the track car. |
It's where it goes in the motor I'm struggling with but cheers for the photo bud________________________________________ Innes drummond |
![]() Seasoned Pro ![]() Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Cheers m8 does that mean you need to remove the wheel and plastic surround thing ? To get access to it ? By m6 do you mean 6 mm ? ________________________________________ Innes drummond |
![]() Senior User ![]() Location: Darlington Registered: 04 Nov 2014 Posts: 545 Status: Offline |
Yea he does mate I've just fitted my standard box, you need to remove the passenger small plastic cover inside wheel arch and the assigner wheel as well really. Very happy with mine, makes the engine a lot more quiet and in my opinion it feels more torque low endDave |
Cool I'll put the cone back on tonight but will attempt this in daylight what did you have on yours before ?________________________________________ Innes drummond |
![]() Seasoned Pro ![]() Location: Winchester Registered: 21 Nov 2003 Posts: 13,753 Status: Offline |
Forget the top bolt it will be missing the captive nut for sure |
![]() Regular ![]() Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
I turned the steering full lock, undone i think 1 screw under the bumper and pulled out 1 clip on the wheel arch. Was then able to pull the liner out enough to get access to the air filter box. If you want to do it properly though better take the wheel and liner off. |
M6 thread, 10mm head.The captive nuts can be bought from pug. ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
Is the k and n cone set up ok performance wise ? Or is original with k and n panel filter a lot better ?________________________________________ Innes drummond |
Thanks for the help have put the k and n cone back on for now but will attempt putting the box back on when I feel confident ha ha really struggling to find these holes in the dark think my air box is missing a stud will put photos up soon ________________________________________ Innes drummond |
![]() Regular ![]() Location: SE Registered: 24 Jul 2011 Posts: 217 Status: Offline |
Call me a pikey but for the top bolt with mentioned missing captive nut, I just used a cable tie through there and the small hole next to it. Along with the other two nuts it's solid! ________________________________________ 1999 Astor Grey GTi-6 OEM+ |
![]() ![]() Location: Kent Registered: 18 Jan 2004 Posts: 21,769 Status: Offline |
matt16v wrote: Call me a pikey but for the top bolt with mentioned missing captive nut, I just used a cable tie through there and the small hole next to it. Along with the other two nuts it's solid! "Pikey". ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone ![]() |
stan_306gti6 wrote: matt16v wrote: Call me a pikey but for the top bolt with mentioned missing captive nut, I just used a cable tie through there and the small hole next to it. Along with the other two nuts it's solid! "Pikey". ![]() ![]() ________________________________________ 1999 Astor Grey GTi-6 OEM+ |
![]() Seasoned Pro ![]() Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
matt16v wrote: stan_306gti6 wrote: matt16v wrote: Call me a pikey but for the top bolt with mentioned missing captive nut, I just used a cable tie through there and the small hole next to it. Along with the other two nuts it's solid! "Pikey". ![]() ![]() i fitted a rivnut so i was able to bolt the filter housing back up there |
