Author Subject: Kad discs for GTi6, eliminates spacers for big brakes!
rallyeash
Hi all,
I have a pair of Kad discs for sale which are 283mm diameter so standard Gti6 size. However these have a back offset by 10mm so the disc itself runs 10mm closer to the car. Combine this with the spacers that are 10mm which you fit between the brake caliper and the hub eliminates the need for spacers.
I have fitted these discs onto my 205 with Kad 6 pots and C5 steel wheels clear with no spacers.
Discs are grooved and there is no wear lip.
so what you get is
4x longer caliper bolts
4x 10mm spacers to move the caliper inwards
2x Kad 283mm discs with 10mm back offset.
fitted onto my 205.
two of the caliper spacers and two of the caliper bolts.
comparing discs... The far one is the disc with back offset and the close one is a brand new 306 gti6 standard disc
£90 delivered
309 3dr K20 Type R
Posted 2nd Oct 2013 at 21:48
rallyeash
Bump, will fit lots of different calipers
309 3dr K20 Type R
Posted 4th Oct 2013 at 22:30
rallyeash
£75
309 3dr K20 Type R
Posted 10th Oct 2013 at 13:10
chrisd306
Might be interested need to measure my discs and see if there same or not
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 12th Oct 2013 at 01:42
rallyeash
Ok.
Let us know.
These are 24mm thick and standard gti6 diameter.
309 3dr K20 Type R
Posted 12th Oct 2013 at 09:04
rallyeash
bump
309 3dr K20 Type R
Posted 15th Oct 2013 at 11:41
rallyeash
bump
309 3dr K20 Type R
Posted 18th Oct 2013 at 15:34
rallyeash
bump
309 3dr K20 Type R
Posted 22nd Oct 2013 at 15:38
rallyeash
Offers
309 3dr K20 Type R
Posted 1st Dec 2013 at 10:57
rallyeash
Bump
309 3dr K20 Type R
Posted 30th Dec 2013 at 10:07
rallyeash
bump
309 3dr K20 Type R
Posted 15th Jan 2014 at 13:30
rallyeash
Bump
309 3dr K20 Type R
Posted 2nd Feb 2014 at 11:38
JWP EFi
Turbo Legend!
out of curiousity are these originally Ford discs? could well be wrong
Posted 2nd Feb 2014 at 19:20
rallyeash
Are designed from Kad to be able to run no spacers and as far as I'm aware are pug designed
309 3dr K20 Type R
Posted 2nd Feb 2014 at 19:22
bitwrx
Do you have any pics of these fitted to a 306? I'm curious about the clearance between disc and ball joint.
Alternatively, a measurement between inner face of the disc and the face that mounts on the hub flange would do.
Thanks,
Charlie
Posted 11th Feb 2014 at 14:19
rallyeash
Didn't see this post sorry.
I'll check it out but there was room on a 309 track 205 so shouldn't be any worse.
309 3dr K20 Type R
Posted 16th Feb 2014 at 15:45
JWP EFi
Turbo Legend!
Pm sent
Posted 17th Feb 2014 at 20:27
rallyeash
Still here
309 3dr K20 Type R
Posted 18th Jun 2014 at 21:57
These are the brakes you bought off Ross?
Might have these off you, saves buying and using spacers. Assume I will be able to run cyclones with these?
Posted 19th Jun 2014 at 08:57
