displaying posts 26 to 50 of 61
Pages (3): 1 [2] 3
Author Subject: Maxi bodied 306 & some interesting history
marco gti6
Has the automatic clicky function stopped working Dunno
Posted 10th Aug 2013 at 16:04
no, some URL's arent compatible though, try using tinyurl to convert it.
Posted 10th Aug 2013 at 16:09
Jon foz
Pug heaven,it has been sticker end up and had a few different paint jobs over the years,will put up a few pics of one of them shortly
Posted 10th Aug 2013 at 16:46
Jon foz
Here are some wishbones he recently made for a 306 competition car
Posted 10th Aug 2013 at 16:47
Jon foz
Here is the car a few years back for pug heaven
This was taken at a hill climb event
Posted 10th Aug 2013 at 16:49
Jon foz
A little taste of what his main business is these days...full motion driving simulators
Posted 10th Aug 2013 at 16:50
pugheaven
Hep that's the one, iv seen a big poster of it somewhere, think it was a performance gti mag pull out poster
Posted 10th Aug 2013 at 16:52
oldbrownshoe
marco gti6 wrote:
Great looking car Love
The rear beam on the maxis where not standard if i remember right thou... Remember seeing pics of a French guy who builds them somewhere on the web.
If you need any help with translations let me know Jon Foz Thumbs up
Edit
This does not look like a standard rear beam Cool
http://www.google.fr/search?q=train+arriere+306+maxi&bav=on.2,or.r_qf.&bvm=bv.50500085,d.Yms&biw=1366&bih=703&pdl=300&um=1&ie=UTF-8&hl=fr&tbm=isch&source=og&sa=N&tab=wi&ei=m1UGUuGeJ8zBswa-jYCIBw
It's the same rear beam configuration as in the 206RC/SW which borrowed it's axel from the 306 MAXI
"From the front of the car to the rear axle is things are mainly the same as the normal 206, except the slightly stiffer springs, shocks, and a Ø21 mm anti-roll bar on the front axle.
The SW rear axle is significantly different from the normal 206: Two ties are added between the suspension arms and meet in the middle onto a cast alloy stay, wrapped around the axle body.
It comes with Ø20 mm spring bars, a 22 mm anti-roll bar and stiffer shocks.
This layout set-up was originally designed for the 306 Maxi by Peugeot Sport and is, next to the SW, now also used in the 206 RC/GTi180, which was introduced in France halfway into 2003.
Because of the more volumetric rear axle, the routing of the exhaust around the rear axle is different from the 206, which ends (as said before), “invisible” pointing 30° downwards, up to 10 cm in front of the rear bumper.
The emergency wheel still hangs in a cradle under the car and is a narrow, weight saver. The jack is the standard GTi scissors type."
http://206gti.net/206sw-review
French military victories?
Did you mean French military defeats?
Posted 10th Aug 2013 at 18:01
oldbrownshoe
buzzbrightyear wrote:
oldbrownshoe wrote:
If i'm right, the original kit car used Pipo modified Mi16 engine ?.
That looks quite technical, there's pipes and wires everywhere, anybody know the spec?
A lot of carbon fibers, about 280-300 atmospheric HP at 10,000 RPM , PIPO was for a lot of years the default choice as engine builder for Peugeot sport,
the 206WRC used 1.8 16V as was in ZX 1.8 dou the aluminum block.
Posted 10th Aug 2013 at 17:49
arigti6
Post #35
So Much want!! Hyper Not a fan of the Maxi spoilers... I feel it spoils it.
The chap who owns/drives the Maxi we see at Pugfest has said the rear beam on it cost 15k...
Jon foz wrote:
^^^ That 309 is F'Kin too low on those wheels! Thumbs down
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 11th Aug 2013 at 22:34
allanallen
Post #36
Edit
A proper maxi beam is nothing like that. From memory its a completly Different beam tube, massive fabricated traing arms and an external ARB. I've got pictures somewhere, I'm sure welshpug will have some to hand though Wink
Facebook
Posted 12th Aug 2013 at 07:23
Post #37
Havent any to hand, but theyre easy to find on google.
Posted 12th Aug 2013 at 08:11
allanallen
Post #38
You disappoint me LOL
Facebook
Posted 12th Aug 2013 at 09:19
Post #39
Link on previous page Roll eyes
Posted 12th Aug 2013 at 15:11
allanallen
Post #40
That's the sort of thing they use on 205s on the continent. 306 maxi, you need to think much more industrial, not sure if these are proper maxi beams but gives you an idea.
Facebook
Posted 12th Aug 2013 at 15:17
Post #41
that's not a maxi beam.
its a 205 beam made by KRS.
maxi V1 trailing arms
V2 beam
Posted 12th Aug 2013 at 15:22
allanallen
Post #42
Yeah I didn't think it was a maxi beam, couldn't actually identify the boot floor! :p gives you an idea how radically different the 'proper' stuff is though.
Facebook
Posted 12th Aug 2013 at 15:33
Post #43
yup, the V2 beam is quite a piece of engineering, probably two and a half times the diameter with proper cartridge bearings and afaik half length torsion bars.
sure I have also seen a variant with a coilover damper as an additional spring.
the first pic you found is a 106 maxi beam.
Posted 12th Aug 2013 at 15:54
Post #44
I've got some of the torsion bars somewhere if I can find them for a picture, they have a little adjustable crows foot in the centre, we use the similar thing on the buggy as a rear bumpstop, just the 306 ones were a bit too large, and the rate was too high.
Posted 12th Aug 2013 at 16:17
oldbrownshoe
Post #45
Edit
it should be similar structure, the diameter and thickness is not the main issue,
" Two ties are added between the suspension arms and meet in the middle onto a cast alloy stay, wrapped around the axle body."
Posted 12th Aug 2013 at 16:23
allanallen
Post #46
oldbrownshoe wrote:
Edit
Not on a maxi beam afaik
Facebook
Posted 12th Aug 2013 at 16:27
midlife
Post #47
I think it would be nice to see a pic of the actual beam that's on itYes
Cool
Team 330™Cool
Team "no front end or engine"
Posted 12th Aug 2013 at 17:54
oldbrownshoe
Post #48
you're turning into beam geeks,
I think it's time to enjoy watching the car in motion.
Posted 12th Aug 2013 at 18:10
midlife
Post #49
http://youtu.be/Rqhjyws5QpI
Cool
Team 330™Cool
Posted 12th Aug 2013 at 18:15
oldbrownshoe
Post #50
Cool
Mine is longer.
Posted 12th Aug 2013 at 18:20
Pages (3): 1 [2] 3
