Author Subject: Smelly RF Caliper?
mik
I've had this on and off for a while, the right front caliper seems to stick and get quite hot so the RF wheel is warmer than the others after going for a drive. Have had the car on stands doing a refurb since March so it has not been driven much. The first couple of drives all the brakes were as cool as a cucumber.
Today I drove it 70 miles - some along motorway at 70-ish and not so much braking, some along windy roads with more braking. After the M4 stretch, it was fine, as I checked car carefully not having driven it far for months. But then when I stopped an hour later after B-road with more braking the RF caliper only was hot and smelly - deffo hotter than the other 3 calipers.
My thinking is a sticky RF caliper. But wouldn't this be constant, not intermittent, so I'm not sure it is only the caliper. Any other possible causes? Any info gratefully received.
Cherry Rallye SOLD
Posted 28th Oct 2012 at 00:38
Definitely sounds like a sticky piston or seized/binding sliders. Get it on stands, pop the wheel off and have a looksee, I think where the cars been laid up a while the calliper has probably partially seized.
Posted 28th Oct 2012 at 01:09
The other thing it could be is excessive play in the week bearing itself allowing the wheel, hub and disc to tilt and rub on the pads generating a fair it of heat through friction, that kind of wear would be pretty obvious though.
Posted 28th Oct 2012 at 01:13
mik
Jim, a wheel bearing had crossed my mind as well. One WB was replaced shortly before I got the car, so this could be the other one giving up a few thousand miles later.
It is also making vibration through the steering wheel combined with a bearing-like noise (though not the noise I usually associate with a bearing), almost a bit "grinding/friction" in feel through the wheel. Again this does not happen constantly and improved somewhat after the car has been driven a few miles.
It started shuddering, with some resonance through the cabin, on the M4, then after about 10 minutes it went away, though the feeling that the wheels need balancing again remained throughout.
Definitely a lot worse since the car has been stood. Before it was perfect.
Cherry Rallye SOLD
Posted 28th Oct 2012 at 06:59
Time to jack it up and give the wheel a wobble then.
Posted 28th Oct 2012 at 07:29
Lecktorious
aka G.
Could be a sticky piston in the caliper, Mik. My car isn't driven that often and I noticed on long journeys I would get a slight 'squealing' which would disappear when I used the brakes. More recently the car has been shuddering under braking and pulling to the right slightly.
Pushed the piston right back in and out a few times today. Seems a lot better now and the braking is a fair bit more progressive too.
'98 Nile Blue 306 GTi 6
Posted 28th Oct 2012 at 12:53
My vote would be the caliper piston...Yes
Out of interest, where was the car stored whilst it's been up on stands? Outside?
My car hasn't been driven for over a year now, but it's stored in a garage and once a week I go outside and pump the brake pedal a few times to stop anything seizing up in the calipers. Smile
Posted 28th Oct 2012 at 14:39
mik
Thanks all, OK sounds like it is the caliper. It was up on axle stands outside because the garage is simply not wide enough to work on the car inside.
I thought the caliper was a bit sticky before the lay-up, but is definitely worse now. I'll check the wheel bearing as well.
Cherry Rallye SOLD
Posted 28th Oct 2012 at 19:11
I guess sitting in the air for 6+ months outside open to the elements (even though it was summer) has possibly finished it off. I'm sure a strip down of the caliper and a good clean will see it back to proper order. Smile
Posted 29th Oct 2012 at 09:53
mik
Thanks for the replies, I've been off-line due to moving house and massive dramas getting a telephone line into a new build house - good old Soviet Bloc circa 1960s customer service. I could have worked around it if only I had got off my @r$e and got an iPhone...
Back on-topic, I got new OE discs and pads, and had a set of SH calipers I'd bought months ago installed. The difference is night and day, the car feels so much better and the brakes are brilliant. There won't be much original bits left at the front of the car when I'm finished.
Cherry Rallye SOLD
Posted 16th Nov 2012 at 17:30
Glad you got it sorted out, you could of serviced the existing calipers, but if you had another set spare then why not. Thumbs up
Posted 16th Nov 2012 at 18:45
