- Fit 306 using the usual 3 bolt holes
- 2deg of extra caster
- Fully adjustable camber 1 to 4 deg with 2.5” coilovers*
- Use 20mm ID spherical bearings
* 1 deg fits the standard cut out and anything above requires the mount hole enlarging as can be seen in pictures below.
It was not economically viable to make just one kit so I had a few made. There are currently 5 kits available, but I am waiting for a couple of people for first refusals.
The price for the kit is £295 collected or £305 delivered.
The kit includes all the nuts and bolts to fit the mounts:
Note: the kit does NOT include the sleeve washers/nuts as there are too many variants depending on which coilovers are used.
Hole enlarged to have up to 3 deg of negative camber:
Mounts set to 2 deg of negative camber.
Cherry Red Rallye Project threadWhiteBMW M140i
